AlfaOBDIs there any way to calibrate surround view at home or it has to be done at dealership?
If the truck is a 2023, and it’s factory equipped with a digital mirror, then there is a 68508050AD camera processor for it under the driver seat.I am at dealership and checked with parts department. They said there are only two modules outside of surround view module: memory seat controller 68534876AC and heated seat module 68592513AA. And the guy at the counter thought that heated seat module could be the one I need for digital rearview mirror. I doubt it, but wanted to double check.
Run the abs initialization routineOne last error code. I think this is the reason for traction control and ACC errors.
I goggled it and only thing I found is that this could be Occupant Restraint Controller issue.
Jimmy, I hope you could shed some light on this. Same thing here, I was not able to find it in Mopar store.
I changed out airbag module below center console, I am not sure if this sensor is part of that and needs a calibration.
Through AlfaOBD?Run the abs initialization routine
Through AlfaOBD?
it’s better because to use the red one you have a picture of you have to remove your speedometer and have small hands to disconnect the security cables and plug this one in. with the Kaodtech you plug it in to the bcm which is located behind the headlight controller. So you can pop out the headlight controller and see exactly what you’re doing and you don’t have to use any tools.Is this cable better because it has dual OBD ends or there’s another reason?
