They have green for gear oil now.Clean it up good with brake parts cleaner and Smear it with some ultra black it will be fine. Probably.
Not even gonna lie olejoe I didn’t even think about vacuuming it out and putting it back in! Hand hits forehead.I would change the bolts out 1 at a time and see if that didn’t stop the leak. Also spray around the outside edge of the cover all the way around with some brake cleaner. I used mineral spirits on mine.
I would vacuum out the Severe Gear and reinstall it.
I looked at that as a possibility but main issue is it recommends after application 24hrs of cure before adding fluids. Don’t have that kind of time window at the shop where I’m doing this at.They have green for gear oil now.81182
Looks good. Does it take a special sump filter with the new pan?
And anyone that dumped 15W40 in it at 38K should be shot.
Seriously asking, why?
Stellantis believes that using a full synthetic oil will prevent deposits as compared to someone using el cheapo conventional 15w-40 at the recommended 15k oil change interval. Stellantis essentially prohibited the use of all 15w-40 oils because of this. I personally feel that a full synthetic 15w40 would be fine, so long as the winter rating was utilized in an appropriate climate. I haven’t run it myself; but, I use 5w40 year round as we dropped to around -8F this winter. If I were out of warranty, and living in Florida for example, I’d run a quality 15w40 without a second thought.Seriously asking, why?
Becuase the lifters aren't compatible with 15w-40.
Its great ATF smells rank but works great lolI was going to use it but when I googled Amsoil ATF there are a bunch of forum threads for oil in general and different RAM truck forums where it’s almost a 50/50 split on yea or nay. The argument I guess is on the fact that they are not ATF +4 certified the company recommends that it meets or exceeds the spec but no independent testing by API or other bodies I am guessing. I’m gonna use it for my transfer case though and most other fluids including oil at the next change.
10-15k depending on duty cycle and what the oil analysis trends.So just did my oil change, fuel filters, cabin air filter, and air filter. She had 8,523 miles on her since it was changed by the dealership on 12/13/24 who sold it to me and 84,212 miles on the odometer. Used Valvoline Premium Blue Synthetic 5w40 and all Fleetguard filters except for the cabin air filter (NAPA enviroshield). I'm sending the old oil which I believe from the service record is Bulk synthetic blend 10w30 to blackstone to have it analyzed. Dash was still showing 48% oil life and 43% fuel filter life but for me oil changes are a once a year deal due to the low mileage. The oil coming out wasn't that bad so I am curious what the analysis says. At how many miles do most of you guys do your oil changes?
What’s your thoughts on speeddiagnostix?10-15k depending on duty cycle and what the oil analysis trends.
FWIW, Blackstone is a mediocre lab. Their turnaround time is slow and you’re paying a lot of money for a partial analysis. (No oxidation test, and outdated / inaccurate flashpoint method for determining fuel dilution. I would recommend Polaris Labs or any other lab that does a full analysis with more up-to-date analyses.
Much better lab than Blackstone and you get an excellent analysis but very expensive.What’s your thoughts on speeddiagnostix?
I didn’t even know Amsoil offered testing, you learn something new everyday. I’ll look into Polaris as I represent 375 Cummins techs including the parts guys. I may go with speeddiagnostix because I’m only going to be doing it once a year so the economics aren’t that bad.Much better lab than Blackstone and you get an excellent analysis but very expensive.
Dollar for dollar, I don’t think you can beat Polaris Labs. You can buy their analysis kits through Fleetguard, Cummins, or Amsoil as all three corporations use them as their independent analysis lab. The kits you buy from Amsoil are the “advanced” kit which gets you a full analysis and they’re also prepaid shipping included. They’re $33 with a PC account.
