SnowmanTX
Howdy folks! Just found this forum and it looks like there are a lot of smart people here, which is just what I need! I've got a new to me 2020 RAM 3500 DRW with the rear only air suspension. One of the bags had a slow leak, so we just replaced them both. The system sounds like it is all working ok, but we have the dashboard message that says to "Service Air Suspension Immediately" or something to that effect. My scan tool returns a code of C156E-00 Ride Height System Calibration Performance. Which, when I research it says that the system needs to be calibrated. We also have an intermittent code of C2212-00 ECU in Plant Mode.
I have tried 3 different scan tools that all have the options for adaptations and writing the ride height into the ECU. The service manual has a procedure for measuring the empty ride height and then entering this data into the scan tool to effectively tell the Air Suspension Control Module where the starting ride height is. One scan tool allows me to enter this data but then tells me that the ECU returned an invalid parameter and the process fails. The other scan tools give me the ECU invalid response before I even get to the screen for entering the ride height.
Some of the other random messages I get from the scan tools tell me that ride height can't be set because the system has not been enabled. The scan tools themselves don't have an option to "Enable" the system, and I don't see an option for this in the vehicle apps either. So, to sum things up, it appears to be telling me that the air system requires calibration, but when I try to calibrate it using the scan tool, it tells me that it can't complete the process because the system isn't calibrated.
I have the instructions for performing the calibration procedure from ALLDATA DIY, but so far I am having no success and seem to be chasing my tail in circles.
Would somebody on this forum be able to point me in the right direction?
Thank you in advance!
