I got my new iDash installed and I need some help with a few of the available parameters:
-On the "emissions" page, I see listed "DPF RG, DPF regen trigger %" but then I also see "PM 1, particulate matter %". What is the difference, and which one gives a picture of the current state of the DPF?
The DPF percentage is what you want to monitor. When it hits 100% a regen will happen. This could be time based or soot based.
PM deals with the particulate matter sensor after the SCR that monitors DPF health.
-What is the difference between "LOAD absolute" and "LOAD calculated", and which is a better picture of what the engine is doing?
-I notice there are multiple EGT sensors. Theres EGT sensors 1 thru 5, but then theres also EGT sensors 1/1 thru 1/5. What is the difference?
Likely the same data just different OBDII protocols.
-Lastly (at least for now), is Trans Temp supposed to available on the iDash? Because depending on which parameter list you read from Banks, one lists trans temp and one doesn't. Can anyone using the iDash on a 2024 confirm if its available on the gauge?
Couldn't tell ya, but the CTS3 has both.
After a regen my banks gauge goes to around 40% and then regens again around 95%.
If you shut your truck off, let it sit for a couple min, and restart soon after a regen the % should drop much lower than 40% and if it doesn't your regens aren't effectivley cleaning your DPF. I've seen multiple single digit reading this way.
Also, regen occurs at 100% and only 100%.
Kinda wish I would have kept my Edge because they've had six years to add lockup status and trans temp as there were available on the 4th gen.
Banks always seems to be developing things for these truck indefinitely.
