Banks IDash gauge-- some Q's
<div class="bbWrapper"><blockquote data-attributes="member: 36565" data-quote="usernamechecksout" data-source="post: 328427" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=328427" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-328427">usernamechecksout said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It doesn&#039;t show trans line pressure. The torque slip is available on the idash but I&#039;ve never got it to show anything. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Interesting. I don&#039;t display that PID any longer, but when I did it definitely worked to show what was going on.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 37987" data-quote="Kopfjager72" data-source="post: 326483" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=326483" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-326483">Kopfjager72 said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> <a href="https://hdrams.com/forum/members/42498/" class="username" data-xf-init="member-tooltip" data-user-id="42498" data-username="@ProspectorSteve">@ProspectorSteve</a> thank you. Quick question. Do you know why I would not be able to see GEAR Trans Gear on my idash as a possible parameter? All I am able to see is TC SLP Torque Converter Slip. Thank you </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I would call their tech support number. I have had good luck with their help in the past. I have it as a choice on mine and it works.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 8297" data-quote="Will_T" data-source="post: 328431" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=328431" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-328431">Will_T said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I would call their tech support number. I have had good luck with their help in the past. I have it as a choice on mine and it works. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Thank you</div>
<div class="bbWrapper"><blockquote data-attributes="member: 16713" data-quote="AH64ID" data-source="post: 326090" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=326090" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-326090">AH64ID said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> All 5 EGT’s are post turbo. I watch EGT1 because it’s in the downpipe and is the best indication of how hard the engine is working. It rarely goes above 1000°F. The engine won’t hurt itself, so what it runs is what it should run (for stock tuning). I also watch EGT3, which is DPF outlet and will tell you if any passive or active regen is occurring.<br /> <br /> DPF DIS and TIM are pointless to monitor as they have been proven to be in accurate on these trucks. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>Can you explain <i>why</i> EGT3 will tell me if any passive regen is occurring? Is it based on temp at that location? If so, what temps indicate passive regen?</div>
<div class="bbWrapper"><blockquote data-attributes="member: 44311" data-quote="ErikTheRed" data-source="post: 330587" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330587" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330587">ErikTheRed said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Can you explain <i>why</i> EGT3 will tell me if any passive regen is occurring? Is it based on temp at that location? If so, what temps indicate passive regen? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> EGT3 is DPF outlet temp. <br /> <br /> When the DPF is at or above ~650° passive regen is occurring. The higher the temp the more passive regen is occurring. <br /> <br /> I’ll add that I’ve seen small indications of passive regen as low as 600° on EGT3 when EGT 1 is higher than 700°. Since EGT3 is DPF outlet the<br /> inlet and mid-DPF temps would be higher allowing for small amounts of passive regen.</div>
<div class="bbWrapper">I wish Banks would bring back the torque convertor lock icon back to the gear indicator. And add transmission line pressure.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 7062" data-quote="G Mcpherson" data-source="post: 330740" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330740" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330740">G Mcpherson said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> When I had My Denali I believe it showed TC Lock UP </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>My &#039;19 f250 had that as well. Maybe I can call them and get it added back lol</div>
<div class="bbWrapper"><blockquote data-attributes="member: 7062" data-quote="G Mcpherson" data-source="post: 330740" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330740" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330740">G Mcpherson said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> When I had My Denali I believe it showed TC Lock UP </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> <blockquote data-attributes="member: 34314" data-quote="deanfx" data-source="post: 330887" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330887" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330887">deanfx said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> My &#039;19 f250 had that as well. Maybe I can call them and get it added back lol </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> It works on the CTS3 so should be available to show.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 16713" data-quote="AH64ID" data-source="post: 330891" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330891" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330891">AH64ID said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It works on the CTS3 so should be available to show. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>It does indeed. I just changed out my CTS3 for a dual Banks setup. The reason I went with a CTS3 is for exterior lighting switching. I&#039;ve since went with Switch Pro&#039;s for switching and Banks for monitoring as I do like the looks of Banks better, but the function is lacking in my case.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 34314" data-quote="deanfx" data-source="post: 330899" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330899" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330899">deanfx said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> It does indeed. I just changed out my CTS3 for a dual Banks setup. The reason I went with a CTS3 is for exterior lighting switching. I&#039;ve since went with Switch Pro&#039;s for switching and Banks for monitoring as I do like the looks of Banks better, but the function is lacking in my case. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> Interesting swap, I definitely don’t see any appeal to the iDash over the CTS3.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 16713" data-quote="AH64ID" data-source="post: 330904" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=330904" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-330904">AH64ID said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Interesting swap, I definitely don’t see any appeal to the iDash over the CTS3. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I can appreciate that for sure lol. I am so weird about things, the cable running to the CTS3 bothered me where the cable on the iDash is concealed. But function over form, the CTS3 is clearly a better product. Until they fix the torque convertor lock status and line pressure.</div>
<div class="bbWrapper">I got my new iDash installed and I need some help with a few of the available parameters:<br /> <br /> -On the &quot;emissions&quot; page, I see listed &quot;DPF RG, DPF regen trigger %&quot; but then I also see &quot;PM 1, particulate matter %&quot;. What is the difference, and which one gives a picture of the current state of the DPF?<br /> <br /> -What is the difference between &quot;LOAD absolute&quot; and &quot;LOAD calculated&quot;, and which is a better picture of what the engine is doing?<br /> <br /> -I notice there are multiple EGT sensors. Theres EGT sensors 1 thru 5, but then theres also EGT sensors 1/1 thru 1/5. What is the difference? <br /> <br /> -Lastly (at least for now), is Trans Temp supposed to available on the iDash? Because depending on which parameter list you read from Banks, one lists trans temp and one doesn&#039;t. Can anyone using the iDash on a 2024 confirm if its available on the gauge?</div>
<div class="bbWrapper">Ain&#039;t nobody got time fo dat? I thought for sure my man AH64ID would be all over this. <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":cool:" title="Cool :cool:" data-smilie="6"data-shortname=":cool:" /></div>
<div class="bbWrapper"><blockquote data-attributes="member: 44311" data-quote="ErikTheRed" data-source="post: 333640" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=333640" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-333640">ErikTheRed said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I got my new iDash installed and I need some help with a few of the available parameters:<br /> <br /> -On the &quot;emissions&quot; page, I see listed &quot;DPF RG, DPF regen trigger %&quot; but then I also see &quot;PM 1, particulate matter %&quot;. What is the difference, and which one gives a picture of the current state of the DPF?<br /> <br /> -What is the difference between &quot;LOAD absolute&quot; and &quot;LOAD calculated&quot;, and which is a better picture of what the engine is doing?<br /> <br /> -I notice there are multiple EGT sensors. Theres EGT sensors 1 thru 5, but then theres also EGT sensors 1/1 thru 1/5. What is the difference?<br /> <br /> -Lastly (at least for now), is Trans Temp supposed to available on the iDash? Because depending on which parameter list you read from Banks, one lists trans temp and one doesn&#039;t. Can anyone using the iDash on a 2024 confirm if its available on the gauge? </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote>I can&#039;t answer many of your questions unfortunately. I had an Edge CTS3 that I sold for a dual Banks iDash setup. The Edge had trans temp and torque convertor lock status which I find important and the iDash doesn&#039;t. I called Banks last week to confirm the lack of convertor lock status and temp status. Their reply was that it will be added sometime in the future. <br /> <br /> As for a EGT temps, I monitor EGT sensor 1 and sensor 3. No idea about 1/1 etc. I also monitor particulate matter %, but can&#039;t tell you what that means exactly. After a regen my banks gauge goes to around 40% and then regens again around 95%.<br /> <br /> Kinda wish I would have kept my Edge because they&#039;ve had six years to add lockup status and trans temp as there were available on the 4th gen.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 34314" data-quote="deanfx" data-source="post: 333948" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=333948" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-333948">deanfx said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I can&#039;t answer many of your questions unfortunately. I had an Edge CTS3 that I sold for a dual Banks iDash setup. The Edge had trans temp and torque convertor lock status which I find important and the iDash doesn&#039;t. I called Banks last week to confirm the lack of convertor lock status and temp status. Their reply was that it will be added sometime in the future.<br /> <br /> As for a EGT temps, I monitor EGT sensor 1 and sensor 3. No idea about 1/1 etc. I also monitor particulate matter %, but can&#039;t tell you what that means exactly. After a regen my banks gauge goes to around 40% and then regens again around 95%.<br /> <br /> Kinda wish I would have kept my Edge because they&#039;ve had six years to add lockup status and trans temp as there were available on the 4th gen. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> The particulate matter % is more based off the timer then anything. so if you regen then sent your time it should hit 95-100% at the 24 hour mark. thats how mine works. <br /> <br /> this is what i monitor on my truck EGT&#039;s are through the roof as i was currently in regen since i hit the 24hr mark. DPFDIS is the average miles between regens. <br /> <br /> <a href="https://hdrams.com/forum/attachments/1736944462834-png.81199/" target="_blank"><img src="https://hdrams.com/forum/data/attachments/81/81207-cc1a59f73a0202b83755dbbdcef5934b.jpg?hash=P7h8U6_-Fk" class="bbImage " style="" alt="1736944462834.png" title="1736944462834.png" width="325" height="150" loading="lazy" /></a></div>
<div class="bbWrapper"><blockquote data-attributes="member: 40281" data-quote="oledirteh" data-source="post: 333955" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=333955" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-333955">oledirteh said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> The particulate matter % is more based off the timer then anything. so if you regen then sent your time it should hit 95-100% at the 24 hour mark. thats how mine works.<br /> <br /> this is what i monitor on my truck EGT&#039;s are through the roof as i was currently in regen since i hit the 24hr mark. DPFDIS is the average miles between regens.<br /> <br /> <a href="https://hdrams.com/forum/attachments/81199/" target="_blank">View attachment 81199</a> </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> PM% is not the same as DPF %. I believe PM% reads the sensor that was missing on most 2022’s, and should read 0% unless there is a DPF failure.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 16713" data-quote="AH64ID" data-source="post: 333956" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> <a href="/forum/goto/post?id=333956" class="bbCodeBlock-sourceJump" rel="nofollow" data-xf-click="attribution" data-content-selector="#post-333956">AH64ID said:</a> </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> PM% is not the same as DPF %. I believe PM% reads the sensor that was missing on most 2022’s, and should read 0% unless there is a DPF failure. </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> your right, i meant the one i monitor the DPFRG. my bad</div>
