I just started watching the final season, so no spoilers, but the ending looked pretty final for Kevin, unless they do a sort of "Kevins of yellowstone past" thing…
Did you see the first 5 minutes of final season episode 1?
Yes, that was my very tongue-in-cheek point, haha.Did you see the first 5 minutes of final season episode 1?
Does anyone know if towing and payloads charts have been released?
Looked through some docs. A couple interesting highlights:
- Adaptive cruise/collision detection/braking is now standard on all trims
- LED headlights and taillights are standard on all trims
- The CHMSL rear view mirror camera is removable/relocatable for use on a cap or slide in camper
- All the trucks appear to have solid center "fake grill" panels in the lower bumper instead of perforated grills like before
- Power steps are no longer available on Rebel
- Rebel and PW base come with the regular hood. The "Sport Performance Hood" requires level 1 or 2
- 3500 Cummins max payloads went down due to the increased weight of the new engine and transmission, which is close to the same amount that the 2500 Cummins GVWR went up, leading me to believe that we shouldn't expect any increased payload on Cummins 2500s.
According to the fleet guide the rebel has front and rear lockers.
No mention of axle size, curious is all 6.7’s get the 12.0” or do the 2500’s keep the 11.5”.
Only gas reg cabs are excluded from the auto-level, so maybe the order code books will get updated.
According to the fleet guide and one of the videos I watched the Tradesman and BH/LS still have incandescent tail lights with an option for an LED upgrade.
I seem to recall seeing something that they all have the 12" rear. If that's the case, the OE 3.73 or 4.10 R&P from the gasser ought to drop right in for all the Karens complaining about the 3.42. LOL.
(Or those wanting to run bubba tires)
unless it’s only available on the gas trucks with the old 11.5 rear axle. Some of these videos of the 2025 show a “axle lock” button on the 4x4 switch set and some videos show the regular 4x4 switch we currently have. Hard to tell what’s going on with the rear locker or what HD truck they would come on.Also means there is an e-locker for the 12” R&P now.
Not sure this guide is right.. it says all models standard V8?According to the fleet guide the rebel has front and rear lockers.
The ‘23 and ‘24 Rebels (and I assume PW) are using the 12” housing with an 11.5” ring gear. I’d bet the locker would fit the 12” gearset too.Also means there is an e-locker for the 12” R&P now.
I've been told by one of the AEV guys that air level will be available for the 3500 - but RAM is just working out the initial orders and will update the order guides later.
Bigger alternator might explain some of the hp loss in addition to the emissions changes?Few things I noticed:
- Hemi down from 410hp to 405hp
- Hemi now comes with 200amp alternator standard, dual is listed as 400amp. 180amp was standard, with 220amp upgrade, or dual at 380amp (220+160)
- No more manual/floor shift transfer case.
Having both fuel filters being engine mounted def seems to be a plus, curious how they handle drain for potential WIF issues, but it's prob straight forward. Prior location of the oil filter honestly never bothered me. You take maybe 1-2 minutes with a cheap, reusable, plastic tool and never have a mess or issue.As far as the Cummins updates.... isn't it strange that out of the Big 3 it ended up being Cummins that redesigns and updates their engine every couple of years to address issues and make improvements now? I really would have never guessed that ten years ago. The "if it ain't broke don't fix it" mentality didn't work for Cummins I guess.
I do like the new oil/fuel filter locations though. The prior oil filter location was a major PITA.
There are two drain petcocks that look identical to the old one, mounted at angles so they should be easy to access. There's a y-shaped hose connected to both.Having both fuel filters being engine mounted def seems to be a plus, curious how they handle drain for potential WIF issues, but it's prob straight forward.
