Not sure if Cummins did this intentionally or if it was a mistaken upload but they have the 2025 engine on their website right now.
Cummins 2025
Cummins 2025
It’s also in the order guides, not that you can completely trust those.Passenger screen confirmed from a source. Was in a Limited.
I like it! https://www.cummins.com/engines/cummins-67l-turbo-diesel-2025?v=10041&application=Pickup TruckNot sure if Cummins did this intentionally or if it was a mistaken upload but they have the 2025 engine on their website right now.
Cummins 2025
It’s in the order guide under what listing? I ordered the limited level one but I didn’t see an option for the passenger screen or 14” center screen. I’m assuming all limited will get both but not sure.It’s also in the order guides, not that you can completely trust those.
Seems like Cummins took the info down on the 2025 6.7L (the above links take you to other engines, can't find the 2025 6.7L anymore) ????
I am ordering a 2025 Limited Longhorn, and yes you do know what you're ordering by using the build sheets that are available, the only difference is you don't get the pictures as you would online. The only thing I'm not sure of is the motor specs.I'm a bit intrigued about people ordering vehicles not having a clue as to what they're getting.
If not mistaken I think the Limited Longhorn gets the 14.4-inch screen along with the passenger screen and just the Limited gets the current 12-inch screen from what I saw on the code sheets.It’s in the order guide under what listing? I ordered the limited level one but I didn’t see an option for the passenger screen or 14” center screen. I’m assuming all limited will get both but not sure.
When you compare this phots against a Duramax motor outside of the truck, it looks like the Cummins has 40% less moving parts.Not sure if Cummins did this intentionally or if it was a mistaken upload but they have the 2025 engine on their website right now.
Cummins 2025
Sometimes you have to wonder if these leaks are on purpose or not. Seems to happen an awful lot. Now if someone will put something up on a revised 6.4, just for a day, that is all. Plenty of time for vultures around here to catch it.
It’s under the standard features for Limited. It’s also listed and as part of Level 2 for Rebel and PW.It’s in the order guide under what listing? I ordered the limited level one but I didn’t see an option for the passenger screen or 14” center screen. I’m assuming all limited will get both but not sure.
Don’t celebrate guys.Not sure if Cummins did this intentionally or if it was a mistaken upload but they have the 2025 engine on their website right now.
Cummins 2025
There is not.
Looks like one.
Unless internals are significantly different, we might see same issues. For example, keyed lifters would fix the issue. We shall wait to see what Bosch has done.Looks like one.
But not one.
I’m wondering if the internals are keyed also.Unless internals are significantly different, we might see same issues. For example, keyed lifters would fix the issue. We shall wait to see what Bosch has done.
For now, just the mere sight of a CP4 external design makes me cringe. If it looks and quacks like a duck…
We will see.I’m wondering if the internals are keyed also.
Wish I could get my hands on one.
I agree, it does not give me the warm and fuzzies.
I hope it’s been reworked. They can’t afford a fumble in any category right now.
