Well, not exactly today but this is what I’ve done in an attempt to come closer to the 2016 Ram 2500 ride I enjoyed before buying my 2024 Ram 2500 CC Hemi 4WD w/4.10 differential ratios.
Thuren +2” soft front springs, front swaybar, front track bar w/ bracket, + 1” soft rear springs w/sway bar connecting links, rear track bar, Fox 2.0 IFP shocks (subsequently replaced with Rancho 9000 shocks to reduce the high speed compression dampening), Fox steering damper, Synergy steering box brace, Michelin 295/70R18 tires (to get a taller sidewall and run at low pressures.
For my use, driving with truck alone, occasional 8.5K loaded equipment trailer and 14K rated dump trailer, both trailers using an Equalizer WDH, I’m pleased with the results.
I ordered and received the Thuren LCS Boogie Bump setup and am anxious to see how my trailer towing goes with the extended bump stops and revised WDH settings.
With just under 3K miles on the truck, it’s really starting to come alive as far as engine performance.
I wired Mopar OEM LED bed lights to one of my aux. switches and a pair of LED rear lights to a second aux. switch. I also installed (2) Moper OEM under hood lights that have integral gravity switches.
+ Bed Rug liner, AMP bed extender and Wheelskins cover.
Throw up some pics, we like pics hereWell, not exactly today but this is what I’ve done in an attempt to come closer to the 2016 Ram 2500 ride I enjoyed before buying my 2024 Ram 2500 CC Hemi 4WD w/4.10 differential ratios.
of the truckThrow up some pics, we like pics here![]()
You have pics of something better?of the truck![]()
Elk hunting. Pin stripes, bummer went 46,xxx miles before scratching. Just had paint corrected and ceramic’d maybe a year ago and some change.
Where did you order the Ranch Hand bumper guard from? How hard will the install be?This is my favorite thread on all the other forums I’m part of it. I haven’t seen it on this sight. If I’m duplicating, I’ll delete! But here is what I did today.
I put on Diesel Fuel and DEF caps and called about Ranch Hand replacement bumper I’m ordering.View attachment 4679View attachment 4681
Looks like you made a lot of changes. Post some pics!I did quite a bit to my new 2024 Tradesman 2500 w/power wagon pkg this week.
1) Aluminum tri-fold tonneau cover
2) Rubber floor liners
3) Side steps
4) mud flaps
5) Kryptek neopreme seat covers
6) license plates (just got it registered)
7) Soft open tailgate strut
8) First oil change
* 9) Having the dealer install a bigger dash screen/infotainment system which should be here now... just have to schedule it.
I am currently researching brighter headlight bulbs. After having LEDs in my last two trucks the halogens just won't cut it.
3) Side steps
4) mud flaps
8) First oil change
Ha! I forgot I added a bug shield... and "Hemi 6.4 Liter" badges to the front fenders like they used to have.Looks like you made a lot of changes. Post some pics!
I can't wait for my 33s to wear out so I can put a respectable sized tire on my PW tradesman, lol.Finally got here.
Looks greatFinally got here.
Will do but I'm afraid it won't be out of the garage until spring lol. The camper has found its home until atleast spring and we have a couple other trucks so I won't be getting it out in the salt.Looks great
Post how they are and especially the road noise level.
Yeah the tires on our nissan needed replaced so I got the idea to get new ones for the ram and put those on the nissan. I did some research and from what i was seeing from everyone is that 35x12.5 with +18 offset wheel would clear. The 295/65's work out to be 35x11.5 and I did go with the +12 wheel so I thought with the tire being an inch narrower and the offset being a little more I would be fine. (+18 to +12 is about a quarter inch) not sure if that is accurate... so with that being said, they rub pretty aggressively on the mud flaps . Not happy with that of course, but maybe they will clear by just removing the flaps...I can't wait for my 33s to wear out so I can put a respectable sized tire on my PW tradesman, lol.
Looks good!
I put that size in the KO2 on +12 wheels on mine no mudflaps and they rubbed just a tiny bit I added a 1" spacer on the coil and it has almost completely gone awayYeah the tires on our nissan needed replaced so I got the idea to get new ones for the ram and put those on the nissan. I did some research and from what i was seeing from everyone is that 35x12.5 with +18 offset wheel would clear. The 295/65's work out to be 35x11.5 and I did go with the +12 wheel so I thought with the tire being an inch narrower and the offset being a little more I would be fine. (+18 to +12 is about a quarter inch) not sure if that is accurate... so with that being said, they rub pretty aggressively on the mud flaps . Not happy with that of course, but maybe they will clear by just removing the flaps...
