superjoe83
Nope, still old 4th gen cabDoes anybody know if the new 2025 2500 gets the 1500 cab?
“ Dodge is losing connection with their base”, Dodge has nothing to do with it, not since 2010.The grille isn't even larger, it's just slightly tweaked so they can fit, what I presume, is some sort of safety device on the front. Fenders appear to have the identical shape, bumper appears identical. Looks like literally just the headlights, lower grille surround, and grille.
They took the absolute worst gen GM, and said "let's run with this!". Even GM realized their mistake with the updated HD trucks.
Pre-redesign Chevy Post-redesign Chevy ![]()
Excited about the new ZF trans, but every day I'm more concerned that dodge is losing connection with their base.
They are 100% at fault for the demise of Ram. Both in general quality as well as customer care. They have no interest in the brand or its loyal consumer base. Their sole interests are swelling their shareholders portfolio and maintaining their progressive, woke, liberalist persona via social media. I know there are exceptional people at Ram who want to provide a quality, reliable, and impressive product to their loyal customers, but their intentions are stifled by the Stellantis hierarchy. They need to just get out of the American market and sell the company to Frank Rhodes Jr. but unfortunately Stellantis has turned his offer down. Sometimes I swear they’re intentionally trying to kill the brandI am afraid Stellantis is the cause of this. I feel like Ram was making progress towards something special for a lot of years. You could see it in marketing, design, and some improvements in reliability and quality. But keeping everyone in the dark for long over due improvements in 2025 to find out those are years away yet while the competition made them years ago, and starting to believe it was purely a ploy to sell down inventory on lots is sad. One new transmission and ugly grill are not news. And now folks are placing orders for who knows what......This is as bad as Fords last 10 new vehicle roll outs!
This is the way.As a CEO I would sit down with actual customer focus groups before making any decisions. I would have a well run forum with specialized forums to discuss highly technical issues, from fixing design flaws, to what size tires for the next power wagon, to do we really need 10,000lb of torque out of the next diesel, or what gear ratios do buyers see as optimal.
Still a good looking truck. At times it seems as if all the manufacturers sit down and compare designs. It doesn't look crazy different from my 2021 3500. Features/performance will be interesting!!??
Will that grille be on the PW ??I don't hate it, but why they didnt change the lower grille to match? I think it would be decent with all vertical slats.
Interesting? Maybe.Still a good looking truck. At times it seems as if all the manufacturers sit down and compare designs. It doesn't look crazy different from my 2021 3500. Features/performance will be interesting!!??
just sold my 2009 Nissan GT-R with 42k on it. Garaged most of its life. The dash was self destructing. $5300 for a new dash not including labor. Horrible quality for a world super car. For some reason, all manufacturers have their QC issues.Now relegated to junk **** boxes and nearly gone. I bought Nissans in the early 2000s, now they are headed the exact same direction
Well it beats the 5.9's solid lifter arrangement. What are you looking for, electronic valve control?? Or did I misinterpret your statement??................still a 6.7 displacement and a hydraulic roller lifter valvetrain.
The 5.9 and 6.7 with solid lifter arrangement is in every way superior to the current hydraulic lifter system currently in use between 19-24. In fact, it’s so poor, it’s currently under engineering review at Cummins because they’re having significant issues with lifters failing prematurely. Rollers spalling, HLA’s not cushioning the valve closure and causing premature wear to the pushrods and the rollers, etc etc. Prior to 19 lifter failure was vertically non existent on these engines.Well it beats the 5.9's solid lifter arrangement. What are you looking for, electronic valve control?? Or did I misinterpret your statement??
Thank you for the explanation. Do you happen to know what the service intervals are on the valve lash? I'm not sure why Cummins is having such problems with the rollers - typically a very desirable setup for wear. Could be an oiling issue related to volume or quality. I have heard of some synthetics causing 'skidding' of certain types of bearings (ball) if I remember correctly. Do you know if there is a white paper on the issue Cummins is having?The 5.9 and 6.7 with solid lifter arrangement is in every way superior to the current hydraulic lifter system currently in use between 19-24. In fact, it’s so poor, it’s currently under engineering review at Cummins because they’re having significant issues with lifters failing prematurely. Rollers spalling, HLA’s not cushioning the valve closure and causing premature wear to the pushrods and the rollers, etc etc. Prior to 19 lifter failure was vertically non existent on these engines.
Cummins doesn’t even use that valvetrain in their commercial B6.7 engines. Only the FCA bound 6.7 engines get hydraulic lifter. That should tell you plenty.
There is no service interval on the current valvetrain because the lash is supposed to be taken up by the hydraulic lifter assembly itself. The rocker arms are not adjustable. There is no external document (yet) but I would expect there will be some viable explanation for some of the issues they’re having at some point. Supplier quality control issues being one of them for sure. As for the roller itself, it is a bushing style bearing. It does not use ball or needle bearings.Thank you for the explanation. Do you happen to know what the service intervals are on the valve lash? I'm not sure why Cummins is having such problems with the rollers - typically a very desirable setup for wear. Could be an oiling issue related to volume or quality. I have heard of some synthetics causing 'skidding' of certain types of bearings (ball) if I remember correctly. Do you know if there is a white paper on the issue Cummins is having?
Lots of good people with great info on this site. I'm coming away from old school 7.3 knowledge to current tech Cummins, lots to learn.
Thanks for getting back to me. I meant the service interval on the solid lifter design. I totally agree with you on the supplier issue. Whether it is a Boeing airplane, Cummins engine or a flippin' blender, it seems that the supply chain is broken if not crooked. since Covid it has been even worse than before. In some ways, I feel bad for manufacturers trusting a vendor to deliver quality products/service. Just look at the airbag debacle. Greed seems to have grown more than 'normal'.There is no service interval on the current valvetrain because the lash is supposed to be taken up by the hydraulic lifter assembly itself. The rocker arms are not adjustable. There is no external document (yet) but I would expect there will be some viable explanation for some of the issues they’re having at some point. Supplier quality control issues being one of them for sure. As for the roller itself, it is a bushing style bearing. It does not use ball or needle bearings.
Hey, I'm curious if you have any vibration issues with your 24. I just picked mine up today and low rpms 40ish mph, its horrible, just sold my 23 for the same reason. ThanksI was really nervous to get mine in 2024 knowing a new one was on the horizon...aesthetics alone, I'm ok w mine, lol. curious to know more about other main changes.
I looked at the post/images regarding the lifter failure. I'm curious if the cam in our trucks are the same as the solid lifter. The images suggest that it is an oil supply failure and/or a hardening issue with the rollers. As you say, time will tell.There is no service interval on the current valvetrain because the lash is supposed to be taken up by the hydraulic lifter assembly itself. The rocker arms are not adjustable. There is no external document (yet) but I would expect there will be some viable explanation for some of the issues they’re having at some point. Supplier quality control issues being one of them for sure. As for the roller itself, it is a bushing style bearing. It does not use ball or needle bearings.
