DRAGRAM
I did several searches using keywords and tried searching title and nothing comes up.
I have never had a dually. Right now I have a 2021 3500 HO Aisin MegaCab short box SRW 4X4 with auto level rear air suspension. I am thinking about buying a 24 exactly the same, but a Dually. Likely the one I get will have 4.10's. So it will pull a lot harder in 6th gear because of the gear ratio and the shorter tires. I am looking forward to that. One reason I am looking at Duallies is because I want rear air suspension and I want to get a 24 and that opens up a LOT more available trucks too choose from. Rear Air suspension is not too prevalent on either version. The other thing driving me this way is because of the new InTech trailer I just bought. It is a 26' Tag that weighs about 11,500 pounds loaded. It tows just fine without any sway control etc. I like to keep it simple and this is working really well for me. But, the tongue weight is #1650 (loaded and unloaded), so with the current Truck I can really feel it now with that higher tongue weight and it is way more bouncy on big transitions in and out of driveways and where the interstate goes over bridges. I suspect a Dually will improve this situation quite a bit. Comments? Ideas?
I get really good mileage with the current truck. But my number is 65 on trips. Will the Dually be very much lower? The new trailer does eat more fuel compared to the 20' @ #9500 total 1300 TW setup I just came out of. About 1MPG worse.
The other things is, what drawbacks will a dually have? What might I not be thinking of? I know it will be harder to park when unhooked, but I do not park up front anyways. I know it will barely fit through toll booths etc, but I have to be on point because of the trailer width anyways. What about backing the trialer up? I am not expecting any big difference here. Other ideas? Experienced Guys please comment. I will be using the Ram as my Primary Vehicle and about 90% of that is towing that trailer. Literally.
