*Breaking News* 2025 Orders from MARK DODGE **
Are the Ramboxes gone for 2025? (didn't see mention of them)
Yes I seen RamBoxes, but I only seen RamBoxes available on Limited, Limited Longhorn, and Power Wagon. Not for sure about other trim levels.
If I were to order a 2500 or 3500 SRW megacab, with box delete, where do they put the trail lights and things that are normally mounted on the tail gate and box ?
I still want to be able to legally drive it and just add on my own topper / rear box.
Thanks
You’re much better off ordering it with the box and then taking it off yourself. The discount they give you is far less than what you can sell the box for.
Pretty exciting updates, although some better than others.
One diesel engine choice is smart.
Anyone have any details on the new HPFP?
Not going to be a CP3.
Looks like a CP4. Hopefully it’s a complete redesign or it just “looks” like a CP4 externally and is a whole new HPFP design.
I wonder if it's the new CP4 that is being put in the Ram/Jeep EcoDiesel under the recall?
The ‘new’ CP4 from the Ecodiesel recall is largely the same pump. The primary difference is lifter surfaces have been hardened which allegedly is similar to some revisions that other manufacturers that utilize the pump have made.
Took me a solid 90 minutes to figure this out. With the summary, you probably don't need the chart - but that's what I had to do in order to figure it out so you get a peak in my brain lol.
It was all a bit surprising from going from Level 1 Level 2, to now having FOUR to choose from, so I had to break it down.
The chart below is for Laramie only but you can use it to understand the code guide itself and how they nest in, mostly.
Let me know what ya think- and as always feel free to let me know if I missed something!
Laramie Main PackagesLEVEL 1Level 1 PlusLevel 2Level 2 PlusAlternative
$895 $1,795 $2,395 $4,895
2ND ROW IN FLOOR STORAGE BINS (CB9)XXXX
ANTI-SPIN DIFFERENTIAL REAR AXLE (DSA)XXXX
AUTO ADJUST IN REVERSE EXT MIRRORS (LEX)XXXX
AUTO DIM EXTERIOR MIRROR (GNZ)XXXX
AUTO DIM EXTERIOR PASSENGER MIRROR (LEU)XXXX
AUTO POWER-FOLDING MIRRORS (LFF)XXXX
BLACK EXTERIOR MIRRORS (LE4) - W/ASHXXXX
CHROME EXTERIOR MIRRORS (LEN)XXXX
CONVEX AUX MIRRORS, POWER-ADJUSTABLE (LFX)XXXX
EXT. MIRRORS W/SUPPLEMENTAL SIGNALS (LEB)XXXX
EXTERIOR MIRRORS COURTESY LAMPS (LEC)XXXX
EXTERIOR MIRRORS W/HEATING ELEMENT (NHJ)XXXX
EXTERIOR MIRRORS W/MEMORY (LEM)XXXX
FOAM BOTTLE INSERT (DOOR TRIM PNL) (CWL)XXXX
FORWARD AND REVERSE UTILITY LIGHTS (LFZ)XXXX
MIRROR POWER HEAT FOLD MEMORY TELE (GT4)XXXX
MIRROR RUNNING LIGHTS (LNY)XXXX
POWER ADJUSTABLE PEDALS W/MEMORY (XAM)XXXX
POWER ADJUST MIRRORS (LF2)XXXX
POWER TELESCOPING MIRRORS (LF4)XXXX
REMOTE TAILGATE RELEASE (JKR)XXXX
#1 SEAT FOAM CUSHION (C1A) XXXBUCKETS (Must have L1 Minimum)
115V AUXILIARY REAR POWER OUTLET (JJN) XXXBUCKETS (Must have L1 Minimum)
2 WAY REAR HEADREST SEAT (CSJ) XXXBUCKETS (Must have L1 Minimum)
4 WAY FRONT HEADRESTS (CDP) XXXBUCKETS (Must have L1 Minimum)
BUCKET SEATS (CAC) XXXBUCKETS (Must have L1 Minimum)
DRIVER SEAT - POWER ADJUST 8-WAY (JVG) XXXBUCKETS (Must have L1 Minimum)
DUAL WIRELESS CHARGING PAD (CMS) XXXBUCKETS (Must have L1 Minimum)
FOLDING FLAT LOAD FLOOR STORAGE (CVN) XXXBUCKETS (Must have L1 Minimum)
FRONT SEAT BACK MAP POCKETS (CSM) XXXBUCKETS (Must have L1 Minimum)
FRT PASS SEAT - POWER ADJUST 8-WAY (JWG) XXXBUCKETS (Must have L1 Minimum)
FULL LENGTH UPGRADED FLOOR CONSOLE (CUP) XXXBUCKETS (Must have L1 Minimum)
HEATED FRONT SEATS (CMA) XXXBUCKETS (Must have L1 Minimum)
HEATED STEERING WHEEL (NHS) XXXBUCKETS (Must have L1 Minimum)
HIGH BACK SEATS (CAD) XXXBUCKETS (Must have L1 Minimum)
POWER 2-WAY DRIVER LUMBAR ADJUST (JPE) XXXBUCKETS (Must have L1 Minimum)
POWER 2-WAY PASSENGER LUMBAR ADJUST (JRP) XXXBUCKETS (Must have L1 Minimum)
REAR 60/40 FOLDING SEAT (CFN) XXXBUCKETS (Must have L1 Minimum)
LEATHER TRIMMED BUCKET SEATS (*GJ) XXX
HEATED SECOND ROW SEATS (JPZ) XXX
RADIO/DRV SEAT/MIRRORS/PEDALS MEMORY (LEV) XXX
VENTILATED FRONT SEATS (CAJ) XXX
ACTIVE LANE MANAGEMENT SYSTEM (XNW) X XSAFETY GROUP (Must have L1 Minimum)
ADAPTIVE STEERING SYSTEM (SJE) X XSAFETY GROUP (Must have L1 Minimum)
TRAFFIC SIGN RECOGNITION (SJB) X XSAFETY GROUP (Must have L1 Minimum)
DROWSY DRIVER DETECTION (XNM) X XSAFETY GROUP (Must have L1 Minimum)
LED BED LIGHTING (LPL) X XBed Utility Group
MOPAR BED STEP - DEPLOYABLE (MDN) X XBed Utility Group
MOPAR SPRAY IN BEDLINER (XMF) X XBed Utility Group
CTR STOP LAMP W/CARGO VIEW CAMERA (LPD) X XSTANDALONE (Must have L1 Minimum)
17 SPKR HARMAN KARDON PREM. SOUND (RCA) XX
UCONNECT 5 NAV W 14.4" DISPLAY (USA) (UBW) XX
POWER DEPLOYABLE RUNNING BOARDS (MY7) XSTANDALONE (Must have L2)
Don't level 1s have Android Auto, CarPlay, SiriusXM, GPS Navigation, etc.? Also, I've been meaning to ask, what is GPS ANTENNA INPUT (JLP)?
Thanks - Updating - there was a group of stuff actually STANDARD feature that was listed again in 2 and 2 Plus, I've updated the chart post.
GPS antenna I mean . . . . I hate to be obtuse but probably just different antenna allowing for GPS use, There isn't an alternative option or feature in the 3500 guide to compete/compare with.
I was wondering if it is an auxiliary GPS antenna input or just the standard GPS antenna input that comes with GPS enabled trucks. Or perhaps for what appears to possibly be a separate GPS antenna in addition to the GPS antenna in the shark fin. I haul a cab-over truck camper which can block the GPS antenna(s).
Every 2022+ HD Ram has the GPS antenna input (for the compass and syncing the clock). It’s also the same as the antenna used when equipped with a navigation radio, and it will always be the puck style on the front of the roof.
Also for 2025, 8.4” is the smallest radio (which is why CarPlay/android auto is standard on every truck), and it is not capable of factory navigation (ie, there isn’t a nav version and a non-nav version like previous years).
Not trying to derail this thread but does that mean that if the truck has both a puck antenna and a shark fin antenna that the shark fin antenna isn't used for GPS input?
