BrianTN
Yes I seen RamBoxes, but I only seen RamBoxes available on Limited, Limited Longhorn, and Power Wagon. Not for sure about other trim levels.Are the Ramboxes gone for 2025? (didn't see mention of them)
I 100% was going to but hit a wall. It seems the only way to ge auto level air suspension on a 3500 is to get a dually. BOOM ! No.Has anyone actually placed an order?
do you have access to a 2025 Ram ? post more photos!
Not going to be a CP3.Pretty exciting updates, although some better than others.
One diesel engine choice is smart.
Anyone have any details on the new HPFP?
Uh oh …?Not directly. Unfortunately, I'm currently still sworn to secrecy. Probably said too much already.
When does the 'sworn to secrecy' end ?Not directly. Unfortunately, I'm currently still sworn to secrecy. Probably said too much already.
Looks like a CP4. Hopefully it’s a complete redesign or it just “looks” like a CP4 externally and is a whole new HPFP design.
I wonder if it's the new CP4 that is being put in the Ram/Jeep EcoDiesel under the recall?
| Laramie Main Packages | LEVEL 1 | Level 1 Plus | Level 2 | Level 2 Plus | Alternative |
| $895 | $1,795 | $2,395 | $4,895 | ||
| 2ND ROW IN FLOOR STORAGE BINS (CB9) | X | X | X | X | |
| ANTI-SPIN DIFFERENTIAL REAR AXLE (DSA) | X | X | X | X | |
| AUTO ADJUST IN REVERSE EXT MIRRORS (LEX) | X | X | X | X | |
| AUTO DIM EXTERIOR MIRROR (GNZ) | X | X | X | X | |
| AUTO DIM EXTERIOR PASSENGER MIRROR (LEU) | X | X | X | X | |
| AUTO POWER-FOLDING MIRRORS (LFF) | X | X | X | X | |
| BLACK EXTERIOR MIRRORS (LE4) - W/ASH | X | X | X | X | |
| CHROME EXTERIOR MIRRORS (LEN) | X | X | X | X | |
| CONVEX AUX MIRRORS, POWER-ADJUSTABLE (LFX) | X | X | X | X | |
| EXT. MIRRORS W/SUPPLEMENTAL SIGNALS (LEB) | X | X | X | X | |
| EXTERIOR MIRRORS COURTESY LAMPS (LEC) | X | X | X | X | |
| EXTERIOR MIRRORS W/HEATING ELEMENT (NHJ) | X | X | X | X | |
| EXTERIOR MIRRORS W/MEMORY (LEM) | X | X | X | X | |
| FOAM BOTTLE INSERT (DOOR TRIM PNL) (CWL) | X | X | X | X | |
| FORWARD AND REVERSE UTILITY LIGHTS (LFZ) | X | X | X | X | |
| MIRROR POWER HEAT FOLD MEMORY TELE (GT4) | X | X | X | X | |
| MIRROR RUNNING LIGHTS (LNY) | X | X | X | X | |
| POWER ADJUSTABLE PEDALS W/MEMORY (XAM) | X | X | X | X | |
| POWER ADJUST MIRRORS (LF2) | X | X | X | X | |
| POWER TELESCOPING MIRRORS (LF4) | X | X | X | X | |
| REMOTE TAILGATE RELEASE (JKR) | X | X | X | X | |
| #1 SEAT FOAM CUSHION (C1A) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| 115V AUXILIARY REAR POWER OUTLET (JJN) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| 2 WAY REAR HEADREST SEAT (CSJ) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| 4 WAY FRONT HEADRESTS (CDP) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| BUCKET SEATS (CAC) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| DRIVER SEAT - POWER ADJUST 8-WAY (JVG) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| DUAL WIRELESS CHARGING PAD (CMS) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| FOLDING FLAT LOAD FLOOR STORAGE (CVN) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| FRONT SEAT BACK MAP POCKETS (CSM) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| FRT PASS SEAT - POWER ADJUST 8-WAY (JWG) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| FULL LENGTH UPGRADED FLOOR CONSOLE (CUP) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| HEATED FRONT SEATS (CMA) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| HEATED STEERING WHEEL (NHS) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| HIGH BACK SEATS (CAD) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| POWER 2-WAY DRIVER LUMBAR ADJUST (JPE) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| POWER 2-WAY PASSENGER LUMBAR ADJUST (JRP) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| REAR 60/40 FOLDING SEAT (CFN) | X | X | X | BUCKETS (Must have L1 Minimum) | |
| LEATHER TRIMMED BUCKET SEATS (*GJ) | X | X | X | ||
| HEATED SECOND ROW SEATS (JPZ) | X | X | X | ||
| RADIO/DRV SEAT/MIRRORS/PEDALS MEMORY (LEV) | X | X | X | ||
| VENTILATED FRONT SEATS (CAJ) | X | X | X | ||
| ACTIVE LANE MANAGEMENT SYSTEM (XNW) | X | X | SAFETY GROUP (Must have L1 Minimum) | ||
| ADAPTIVE STEERING SYSTEM (SJE) | X | X | SAFETY GROUP (Must have L1 Minimum) | ||
| TRAFFIC SIGN RECOGNITION (SJB) | X | X | SAFETY GROUP (Must have L1 Minimum) | ||
| DROWSY DRIVER DETECTION (XNM) | X | X | SAFETY GROUP (Must have L1 Minimum) | ||
| LED BED LIGHTING (LPL) | X | X | Bed Utility Group | ||
| MOPAR BED STEP - DEPLOYABLE (MDN) | X | X | Bed Utility Group | ||
| MOPAR SPRAY IN BEDLINER (XMF) | X | X | Bed Utility Group | ||
| CTR STOP LAMP W/CARGO VIEW CAMERA (LPD) | X | X | STANDALONE (Must have L1 Minimum) | ||
| 17 SPKR HARMAN KARDON PREM. SOUND (RCA) | X | X | |||
| UCONNECT 5 NAV W 14.4" DISPLAY (USA) (UBW) | X | X | |||
| POWER DEPLOYABLE RUNNING BOARDS (MY7) | X | STANDALONE (Must have L2) |
Thanks - Updating - there was a group of stuff actually STANDARD feature that was listed again in 2 and 2 Plus, I've updated the chart post.^^^
Don't level 1s have Android Auto, CarPlay, SiriusXM, GPS Navigation, etc.? Also, I've been meaning to ask, what is GPS ANTENNA INPUT (JLP)?
I was wondering if it is an auxiliary GPS antenna input or just the standard GPS antenna input that comes with GPS enabled trucks. Or perhaps for what appears to possibly be a separate GPS antenna in addition to the GPS antenna in the shark fin. I haul a cab-over truck camper which can block the GPS antenna(s).Thanks - Updating - there was a group of stuff actually STANDARD feature that was listed again in 2 and 2 Plus, I've updated the chart post.
GPS antenna I mean . . . . I hate to be obtuse but probably just different antenna allowing for GPS use, There isn't an alternative option or feature in the 3500 guide to compete/compare with.
Every 2022+ HD Ram has the GPS antenna input (for the compass and syncing the clock). It’s also the same as the antenna used when equipped with a navigation radio, and it will always be the puck style on the front of the roof.I was wondering if it is an auxiliary GPS antenna input or just the standard GPS antenna input that comes with GPS enabled trucks. Or perhaps for what appears to possibly be a separate GPS antenna in addition to the GPS antenna in the shark fin. I haul a cab-over truck camper which can block the GPS antenna(s).
Not trying to derail this thread but does that mean that if the truck has both a puck antenna and a shark fin antenna that the shark fin antenna isn't used for GPS input?Every 2022+ HD Ram has the GPS antenna input (for the compass and syncing the clock). It’s also the same as the antenna used when equipped with a navigation radio, and it will always be the puck style on the front of the roof.
Also for 2025, 8.4” is the smallest radio (which is why CarPlay/android auto is standard on every truck), and it is not capable of factory navigation (ie, there isn’t a nav version and a non-nav version like previous years).
The shark fin never is/was used for gps. Shark fin is for AM/FM radio and cellular. Puck has always been for gps/sdars.Not trying to derail this thread but does that mean that if the truck has both a puck antenna and a shark fin antenna that the shark fin antenna isn't used for GPS input?
