Rockcrawlindude
a rock crawlin’ dude
The Hemi shines for people that tow sub 10K. It can do more but it’s not gonna shine.
You’re buying too much trailer for that truck.
Owners manuals are not guidelines of any laws.
There is no law requiring anyone to follow the owners manual anywhereBut laws do, in many cases rely upon the operator, mechanic, etc. following the owners manuals.
Interesting!When I had my F350 dually blah, blah, blah, it was registered with a GVWR of 26000 pounds. When I traded it in on this truck the DMV folks suggested I simply transfer my plate to the new truck since I had so much time left until renewal, so I did. Until that plate expired my Ram 2500 was registered with a GVWR of 26000 pounds. When I went to renew the folks at the DMV said it would be cheaper for me to keep my class B plate but reduce the GVWR. Since it had to be over 10000 pounds to qualify as a class B they registered it for 11000 pounds GVWR.
When I bought my 2020 2500 they registered it in NC as 0 pounds as well.Interesting!
My 2500 was registered with a GVWR of 0 (zero) for the first three years I owned it. I found out because the first three years are emissions exempt and >8k lb are also emissions exempt. After three years I went to renew and the system prompted me that I needed an emissions report for the truck.
Registration showed 0 on the GVWR. I noticed that and never thought much of it, just assumed it was because it was over 8k. Got it sorted out fairly quickly and easily over the phone with the DMV and registration now shows 10k as it should. Apparently the selling dealer submitted the paperwork with GVWR as 0 or left it blank
Go ahead and quote yourself in court and see how that works out for you.There is no law requiring anyone to follow the owners manual anywhere
I have a 6.4 with 4.10s also and pull a toy hauler it weighs 11500 to 12000lbs. It pulls it ok I can maintain at the speed limits. Some long hills of Utah are ok but not fun. We use this trailer a handful of times a summer. If I pulled any more weight or more often I would look into a Diesel. Over all I am happy with the 6.4 Hemi. I would not pull 17000 it. Good luck to you. We all have different needs.
Ok ill play your silly game… the manual clearly shows a 2500 with a 5th wheel hitch is rated for a maximum towing at 25,000 lbs or the GN 20,000lbs or 20,000 lbs class 5 hitch so does that mean it can tow it? The manual is not a legally binding document never has been never will be ( most are more even giving the owners a manual these days)Go ahead and quote yourself in court and see how that works out for you.
There are actually legal requirements related to minimum safety equipment, emissions equipment and warranty within the manual. It is referred to by the FTC and NHTSA in several documents.
