2023/2024 Digital Cluster Upgrade?
There is no programmers that you and I can use yet to do this yet.
CAN I CHANGE HOURS AND MILEAGE ON THE STOCK CLUSTER WITH ALFAOBD? 2023 RAM 2500 MEGA LARAMIE.
I have the harness available (already been supplying them to 1500 owners that have been doing this swap), and applying the alfaobd settings are a little unconventional since they are not in the settings list, so I would walk you through step by step how to do that.
Where can I get the harness and the step by step to config. I have 2023 2500.
Any idea on why the ring for oil temp gauge is missing ? TIA
Is it the position it's in, can you move the gauges around? Looks like the ring might encroach on the MPH display.
It's a known programming glitch, the ring for the Oil temp Card doesn't work either. Don't know if it's something they'll address with a dealer firmware update or not... Knowing Stellantis though we're probably SOL.
Another fun programming error is the Diesel version of the cluster is missing the card for transmission temperature...
We’re going the remap the left buttons with arduino route.
The steering wheel controls message ID change for the new steering wheel setup for 23 reaches out to too many modules.
The guy I got it from had to swap in the 23 wheel, buttons, wheel wiring, steering column control module, custom harness for that, and the BCM. That’s when we found out the abs module and PCM are also affected. That’s when he called it quits on going that route.
I have 2023 ram 2500 what parts I need for swap a digital cluster ? Thanks for u help jimmy
You need the cluster, left steering wheel switch, alfaobd, and a custom harness that I build.
Ok good I have the cluster already . Have the part number for steering wheel switch ? Where can I get the harness??
Steering wheel switch 68529653AB.
You can get the harness from me, send me a direct message.
@Jimmy07 thanks for helping us out. So I have a 2020 Ram 3500 Limited. I recently purchased the U connect 5 12" screen and radio module for a 2024, the Ebay retro harness, and the needed new CVPM module part # 56029967AF that Infotainment mentions. I haven't installed them yet but want also do the digital gauge cluster as well. Could I trouble you for the needed part numbers for the Limited digital gauge and steering wheel switch for my 2020? I know I need to purchase the cluster harness from you. My understanding is if I upgrade to the Uconnect 5 screen and radio module the navigation will show up on the cluster? Any other features would I gain or lose from doing the U Connect 5 upgrade with the digital cluster? Thanks for the help and guidance, I appreciate it!
Where u get the digital cluster ??
I don't have it yet bud, but I have a good source. Trying to make sure I have all my ducks in a row before spending. Pretty decent amount being invested between the UC5 and now the digital cluster. Would eventually like to add the digital rear view mirror too.
What Jimmy is doing is perfectly fine, he's an established contributor.
However, there's no posting ads in the forums allowed. It's too hard to police. If anyone sees this, please report the posts.
You can let members know you have items in the BST forum, they can go there.
Hi jimmy07. Could you provide me the cable to switch my 2022 ram gadget cluster to my new2023 12" gadget cluster?
I got the module working and got the maps working too .
This is all on my 18 truck with a 18 bcm
I have a few modules out there .
Jimmy is making the harness and I am providing the can bus module interface that plugs into his harness .
Still need a 2023+ uconnect right? The 2022 UC5 won't work correct?
