RKCRLR
But how important is the exhaust brake when just loaded to 14K GVWR? Or even GVWR + 5K lb trailer? I've never had a problem overheating my brakes just downshifting my gas engine when going downhill.@UglyViking FWIW my 3500 SRW with auto level and 5th wheel prep (both mentioned as possible by the OP) was 3400lbs new with 3/4 tank of fuel (50 gallon tank) and me in it. Nothing else. A DRW with the same options would easily be over 3800lbs as they are 413 lbs heavier per Ram than an SRW.
Just an observation on RAW.
@RKCRLR you have listed the main benefits of the diesel, but didn’t list then exhaust brake or added stability from a higher FAW.
The diesel will also use less fuel, not more.
The C&C diesel is its own build and has much fewer emissions issues from lighter use as it’s more designed for it.
The rear auto-level will likely work well above RAWR, it’s not something I’d be concerned with if you end up with one in a pickup.
The advantage of a C&C is a much more robust frame and suspension desired for content load at RAWR. It will handle better, and most importantly last longer at the same weight that a 3500 would. Truck campers are hard on frames and suspensions, but a 4500 wouldn’t even notice one.
I didn't mean the diesel will use more fuel, just that diesel costs more per gallon than gasoline where I live.
Does the C&C still have EGR and particulate filters? From my understanding those are the main things that have problems during repeated short trips.
Again, while I can appreciate a more robust frame from what I've read this thread the 3500 can be loaded above GVWR without problems so I should be fine if I remain within GVWR. I haven't seen what a 4500 C&C outfitted to serve dual purpose as a pickup and camper carrier would cost but it doesn't seem cost effective for a truck that will only see 30K - 45K miles during my ownership. If cost were no object then I'd be going in a different direction.
