MOPAR Steering Fluid or ATF4?
2500Ram
Maryland
What steering fluid for my 22 Cummins?
My 2020 Owners Manual says MOPAR Power Steering Fluid +4 or MOPAR ATF+4
My 2022 owners manual only lists PS fluid under the 6.4 but it should be the same for both 6.4 and 6.7 application, which is the same as what @John Jensen mentioned.
Mine says either or but I didn't want to mix. I will replace with fresh ATF 4 since a quart is so cheap.
Do you have a leak? Steering fluid lasts forever
I don’t feel that way, it goes under pretty high abuse on most engines but even more so on these diesels with hydroboost. It gets hot, has minimal cooling, and doesn’t have a high volume. Along with brake fluids it’s one of the most neglected fluids on a vehicle.
I do regular fluid exchanges on all my PS systems.
