Well that's cool. I always feel poor hereThe sliding tray in my console has bugged me since day one. It looks untidy and incomplete. Today I installed a Limited tray. Way too much money, but I feel much better now.
Oh and also powerstop Z36 pads and their Geomet rotors all 4 corners.
GM reps in 8x6.5. They are 22x10 +35 offset.What are the specs on this wheel? Brand? I am very interested, thanks
+35 on a x10 wheel is +15 on a x8.5 wheel.Where can I find more info?
I found this, but the offset is too far out (I want +35mm not +15mm) https://www.ebay.com/itm/126440044113?itmmeta=01J1KBRT7PBMXYA9HNKTFXY5QP&hash=item1d7069f651:g:aaYAAOSw0DNmItsp&itmprp=enc:AQAJAAAA0M+whjTJIUs/FR6z/Vaof9dbK3UAeaLuS+08f1T6XqJCR6Yyi8BApd/jtV8ByHZ5+gyyZXPctCSQ0lWeDMVLw3/Z6YkwhF/utpV2Q+YyWcCcGZQj28ZhAsjwZWOYhSG6W4qSWOEg6JbGcJmdxzDhSTalU/+SPZcn52gQAZIlDwfPXhv+RdtQ3UA4ED3wsKvk/sYLSCv7sQUXWvzMnmJ2bmoHKwZc6EaESKLsvw6akIMYidTP+rNocu3WniwUsjPSJO2NieZo5M960tDPsaQq2vU=|tkp:Bk9SR_qj4-uMZA
Looks greatThe sliding tray in my console has bugged me since day one. It looks untidy and incomplete. Today I installed a Limited tray. Way too much money, but I feel much better now.
Looks great
However, dude spill the beans on the install details.
So far so good... No noise, vibration, or anything negative to say. The rotors were coated really thoroughly with their geomet protection which is important to me living in a salted road region. All in all I'd recommend to anyone.How do you like these?
My truck, unfortunately with only 24k needs brakes. Calipers are all free but the back side of the stock (front) rotors are trashed. Pretty disappointed. I tow the 5er but have never been hard on them IMO and complained since new how lackluster the factory pedal was.
I have a Powerstop kit on my Subaru and they have treated us pretty well. They need to be warmed up before they really bite but that’s a known.
Sent from me
I honestly don't quite understand why they don't sell/offer a kit with the z36 pads and the solid rotors(though I didn't call them). I'm not a believer in slotted or drilled on a HD truck... But to each their own.
You just said the same thing as me in other words. Offset and backspacing are a direct correlation of one another. Here is a visual representation.Offset is offset, regardless of wheel width. Offset will always tell you how far the center of your wheel/tire is moved in or out. If you have a ten inch wide wheel with 5.5" of backspacing (allowing 0.5" for the wheel lip), that is a zero offset wheel. The same 5.5" of backspace on an 8" wide wheel is a +25.4mm and will move the center of the tire in 1".
My stock wheels are 20x8" with +54mm offset, the +15mm offset will move the center of the tire out by 39mm or 1.535", which is too far for me, I would like to only move the tire out by about 3/4" of an inch.
The perfect wheel for me would be a 18x9" with +35mm offset, I would run 37x12.5 tire on that.
Bingowhat your photo is showing is that the outside of the wheel will be in the same place on a 10" wide wheel with +35mm offset as a 8.5" wide wheel with +15mm offset. However, the center of the tire will move in by half of the 1.5" or 39mm, or roughly 3/4" or 20mm...
Saying “offset is offset regardless of wheel width” is misleading. Offset means dick without the wheel widthOffset is offset, regardless of wheel width. Offset will always tell you how far the center of your wheel/tire is moved in or out. If you have a ten inch wide wheel with 5.5" of backspacing (allowing 0.5" for the wheel lip), that is a zero offset wheel. The same 5.5" of backspace on an 8" wide wheel is a +25.4mm and will move the center of the tire in 1".
No. We weren’t talking about backspace.Don't you mean "BACKSPACE is BACKSPACE regardless of wheel width" is misleading?
Nice.
