Just picked up my 24 SO Cummins and 68rfe 3 weeks ago. Its been shifting rough from day one I only have 700 miles on it currently. Seems like if i drive normal or stop sign to stop sign you can feel every single shift. If you drive more aggressively ( highway merging) it shifts smoother up until 4th gear to the point where there's a surge/Delay between neutral and the next gear. Just seeing if anyone else has similar shifting and its just the truck. Came from a 10 speed GM that you couldn't even tell was shifting. But i also have a 5500 Ram chassis cab with an Asin that seems like it shifts smoother throughout. Not sure if the transmission is still in learning or when they normally break in.
