Rockcrawlindude
a rock crawlin’ dude
Thanks they look great. They’re a hair smaller than what I’ve got but I run a little more psi. I’m getting close to needing new tires.front tires at 40 PSI are almost 34".![]()
So I have a Kenwood VHF 110W radio that I use when I do race support down in Baja and out in Nevada.
I didnt want to cut up or drill into the new truck so I've been working on designs. Heres what I've come up with so far.
The main. Radio will be mounted under the back seat on the passenger's side. It fits behind the factory sub and amp. I originally built a back angle bracket i had plan on bolting down using the back outer seat bolt and the seat belt mounting bolt.
But once i got the bracket in, i found out i cannot get to the seatbelts bolt.
So I'll mount it to the seat bolt and just put the "tab" behind the seat belt mount. Once tight, this should hold the radio in place. I also built a front mount for the radio. This is so I can raise the radio an inch off the floor to get air all around it. Yea, I miss drilled the front mount and have to refill it so the base is u NV der the radio.View attachment 20115View attachment 20116View attachment 20117View attachment 20118
I knew the user name looking familiar from RDC! Great thread!
Back at the tire shop. Got the "Death wobble" at 50 MPH. Adding a little more balance beads and adjusting the alingemet to
Toe 0 or a little toe in.
Castor back to 4.25 to 4.5 with 0 cross castor.
Need them for the snow and mud when I move.I am sorry sir, but you are being overly aggressive! Those are some good looking tires. I have friends running them on their Jeeps and they love them.
Wow I would not have guess that they would lasted so few miles.So after 21K on my MT tires, it's about time to replace them. They are almost at the wear bars. They did work good, but I think I may only get 25K out of them, if I'm lucky.
I ended up trying the Centramatic wheel balancers for the 39 inch K02s on the H1 and they work fantastic!!!! No one could spin balance the 39s and I didn't want beads floating around the inside of the tire.So took all 4 tires/wheels off and dropped them off at 4Wheel Parts in Reno to see what's going on. We found the issue. Strangest thing that in 20 + years of using balance beads, I've never seen this. Seems to of the tires, the bag never broke open. So the tire was always out of balance.
So they went the old school route and put regular weights with the spin balance.
My death wobble and vibration is gone. Truck rides nice now.
Quick sidebar (sorry @Crusty old shellback!) did you have the tire shop attempt to balance the tires with weights and used the Centramatics as additional support, or did you only run the Centramatics?I ended up trying the Centramatic wheel balancers for the 39 inch K02s on the H1 and they work fantastic!!!! No one could spin balance the 39s and I didn't want beads floating around the inside of the tire.
UglyViking,Quick sidebar (sorry @Crusty old shellback!) did you have the tire shop attempt to balance the tires with weights and used the Centramatics as additional support, or did you only run the Centramatics?
And @Crusty old shellback, I've heard that BFG has updated the larger size KO2s and KM3s to better account for the weight of these larger rigs. No direct experience but that is what I've read. Allegedly this spring/summer they are releasing the new KO3s, which may be something to look at if you can stretch them out a little further. I'm looking at stepping up to 39s and am currently trying to hold out for the new KO3 to see if they also come in a 39" (basically 0 options for a 39" AT tire as of the moment).
Past that, if you're sticking with 37s, I think there are a lot of options that may be better, with newer tread and rubber tech than what BFG offers. I know a lot of guys have been exceptionally happy with offerings from Mickey and General along with the obvious non RT flavors from Toyo, Nitto, and Falken.
Looks like I have the same issue and will need that 2014 CBC Config deal..... thx for all the information!!!!OK, so I've been having a issue in that my mirror mounted auxiliary reverse lights would go out every time I started backing up the truck.
Asked the question on here and others say theirs works fine, and we couldn't understand why mine didn't.
Then one member said something about Cailf not allowing cargo lights on when the truck is moving.
So I went digging into the owners manual. Sure enough, right there in black and white in a note, it states California AND Mississippi do not allow the auxiliary reverse lights to work while the truck is moving. WTF?
So me being me, I started looking around in my ALPHA OBD and found this.
If I go into the BCM, scroll to the bottom I find
Car configuration change.
So I click on it and then go to select option and scroll down about half way and find
2014 CBC Config I/O & Feat.-Baggage (Cargo) Lamp Output Disabled with vehicle moving
I then hit set value and select no. then start.
And it changed my setting.
Backed everything out and tried the mirror lights.
THEY WORK! So I now have the mirror axillary reverse lights on my Calif truck. Yea me.
