“Renewable Diesel” and “Biodiesel” are nothing alike except that they both are sourced from biomass sources. Aside from that, they are fundamentally different and have vastly different characteristics pre and post combustion.
Renewable diesel is a drop-in replacement for hydrocarbon fuel like ULSD and is virtually indistinguishable from its petroleum based counterpart.
Biodiesel (also known as FAME biodiesel) has vastly different characteristics than conventional petroleum fuel or renewable fuel. Most biodiesel is sold as a “blend” that is mixed with petroleum fuel and giving a rating percentage like B20, B5 etc. (where the number represents the percentage of bio mixed in). Our 2019+ trucks are rated up to B20 compatibility, however regular use of fuel above B5 requires a significant change in maintenance intervals, as it has some less than desirable effects on the truck.
What the dealer is suggesting has merit. If you log data extensively on these trucks (like I do) you will see that the use of higher percentages of Biodiesel in these trucks has negative impacts on fuel economy, increases the need for more frequent regeneration cycles, reduces the effectiveness and ability for passive regeneration, and also increases fuel dilution in the engine oil.
I was dealing with a frequent regeneration issue for several months. Through my own research and experience, I was able to correct the issue primarily by switching where I buy my fuel. The previous station used a much higher percentage of biodiesel in their fuel, while the new station has very little biodiesel in the fuel at all. (B2 or 2% biodiesel is state-mandated in Pennsylvania)
