Sadly none that anyone has found.Are there any ACC settings available in AlfaOBD? Looking to simmer down the braking/acceleration
Thank you for posting... I have had the same issue and could not get in due to the verification. will try this tonight. I appreciate you working through this with the group!Alright. If I go into preferences and check “Do not verify ECU model” I can finally see stuff (just trying to lower TPMS thresholds lol). But I’m a little nervous by this warning on this checkbox…
Problem solved - laptop change and we are in business. Fog dropout and current gear done. Ready for 35s now that I can correct speedo!Good evening all -
I’m having no luck connecting my 2019 PW to AlphaOBD by way of Kaodtech and LinkerMC. I am using Alpha on a Windows 7 laptop and Bluetooth appears to connect to the Linker.
My bypass cable was at first swapped due to Kaodtech changing the wires/bases around but it now has blue/yellow in the connector closest to the drivers seat.
When I try to connect Alpha, it saying it’s trying to connect to CAN then gives me an error that it’s not receiving from the interface.
Any ideas? Thank you for any guidance.
I’ve looked around in AlfaOBD and don’t see anything that seems likely to control this, looking at everything with “heat”, “temp”, “remote”, or “threshold” in it.I searched this thread for "temperature" and didn't find any results. Is it possible to modify the threshold for turning on heat/heated seats/heated steering wheel on remote start? On my 2017 1500 LImited when I used the remote start and it was below 40 degrees, the truck would turn on the heated items automatically. I'm picking up a new truck this weekend and an alfa for the wireless charger install. I would like to enable the heated settings at, say 60 or 55 degrees as opposed to below 40.
It’s in the heated seat module which AlfaI searched this thread for "temperature" and didn't find any results. Is it possible to modify the threshold for turning on heat/heated seats/heated steering wheel on remote start? On my 2017 1500 LImited when I used the remote start and it was below 40 degrees, the truck would turn on the heated items automatically. I'm picking up a new truck this weekend and an alfa for the wireless charger install. I would like to enable the heated settings at, say 60 or 55 degrees as opposed to below 40.
It’s in the heated seat module which Alfa cannot access. We’re stuck with the shortsighted Ram engineers’ decision of hard coding the heated features on below 40 and cooled seats on above 80.
Yeah, that part is the most annoying. I mean, it’s not a problem for me, but my wife doesn’t like the cold seat!And only the driver seat... Ugh.
Instead of connecting to the body computer, you’ll connect to the comfort seats and wheel module. That’s where you’ll find the auto on temp limits adjustments:I searched this thread for "temperature" and didn't find any results. Is it possible to modify the threshold for turning on heat/heated seats/heated steering wheel on remote start? On my 2017 1500 LImited when I used the remote start and it was below 40 degrees, the truck would turn on the heated items automatically. I'm picking up a new truck this weekend and an alfa for the wireless charger install. I would like to enable the heated settings at, say 60 or 55 degrees as opposed to below 40.
So we can adjust the temps?!?Instead of connecting to the body computer, you’ll connect to the comfort seats and wheel module. That’s where you’ll find the auto on temp limits adjustments:
YesSo we can adjust the temps?!?
Excellent! I stand corrected.
This sold me on getting it, thanks
Regarding how to increase the 85 mph governed cruise control. I know this is an old thread. Can you advise how to get to this menu within the alphaobd s/w? This is probably the most annoying thing on my Ram, second to the weak sub.
