Have a 2021 ram 6.7L and I am having an issue where under mid to heavy thottle (boost in the 15psi) range it will cut out and buck and stumble so bad that i need to let off and milk it, it will continue to idle sporadically for a bit. It doesnt do this if you are babying it under very light throttle. It was throwing a check engine light for NOX sensor which dealer replaced, now no check engine lights but still experiencing the same issue. Could it be the fuel filter? Seems strange there are no codes being thrown...Any suggestions?
