jabartram
- Age
- 56
Do you have the bypass cable?Anyone connect to a 2021 with an android yet? I am having issues.
Sent from my SM-N986U using Tapatalk
I do. I am pretty sure I connected everything properly and I am getting an ISO error saying it cannot connect to the ECU. How did you connect the bypass cable to the CAN blocks. I want to make sure I did it right. I followed the directions Kaodtech provided.
Sent from my iPhone using Tapatalk![]()
Sent: Friday, December 27, 2019 1:42 AM
Subject:Re: Unknown ISO code
The message means that the ECU is not in the app database
yet. I'll add the data in the next release. ISO code is not
relevant for RAM, it's OK that it's empty.
Best regards,
Alexey Chernikov
AlfaOBD
I had the same issue today with my 2021 using Windows. I contacted Alfa OBD and was told to use it and it will work. He is working on the 2021 models.I do. I am pretty sure I connected everything properly and I am getting an ISO error saying it cannot connect to the ECU. How did you connect the bypass cable to the CAN blocks. I want to make sure I did it right. I followed the directions Kaodtech provided.
I hate to be the bearer of bad news, but in every story I’ve read of someone managing to bork the speed limiter with AlfaOBD the only fix was a new ECM.Hello, All i know its like beating a dead horse by now. I have a 2019 HO DRW i used Alfa for a few changes. Most worked fine i tried to figure out how to fold mirrors on lock never did. Well i tried to remove speed limiter and well now at 70mph it just falls flat. I changed from Engine & body computer and tried to load from saved file and it just says ecm failed to load says wrong parameters. ive tried for many hrs and just cant seem to figure out how to just set back to factory settings. Thanks Bill Woodard
If I recall, mine is set to 500. It has to be in kph.I will keep trying at one point i had it to a MAX of 45mph. then kept trying now im up to 70. i thought there was a easy fix thank you for responding.
I have no reason to be over 102 lol as mine has 4:10 gears anyway.thank you i will try 500If I recall, mine is set to 500. It has to be in kph.
FYI, this doesn't actually remove the 102mph limit, only a tune can do that.
