MEZZ2006
This is what I was thinking of getting so as not to go thru that again.
Security Module Bypass | KaodTech
Will Ship 3-5 Business Days after OrderIf you have a 2018 - 2024 RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you.Does this allow access to all modules?It has been tested connecting to the BCM...www.kaodtech.com
This is what I got for my truck. Very high quality and easy to install.
I turned on fog lights with high beams. I tried global window down, but that didn't work. At some point I would like to add the proximity entry, where you just grab the door handle to unlock the doors, but I'm waiting for someone else to do it first. I also plan to add led bulbs in the front turnsignals, at some point, so I will set those lights to LED in AlfaOBD when I add them.
