Idle Speed Control / PTO Speed
dieselscout80
Can AlfaOBD or JScan enable the PTO Prep option sales code LBN or LBV enough to control the idle speed to say boost idle speed when jump starting a vehicle?
I think you can use cruise control when in park to set the truck at high idle, if I understand what youre asking about correctly.
You can, that's on all Cummins trucks (no idea about Hemis), but there is also a separate option code (XF6 or something, I don't recall) that will have the truck idle up automatically in response to higher voltage draws. That is in the engine section of AlfaOBD I believe, I plan on tinkering with that once I get more things hooked up to my truck to generate enough load.
Are there any hard parts to install? Or just enabled in the BCM?
Somebody (maybe Jimmy but I am not sure) told me in another thread that there is no associated hardware. I don’t see why there would be. I won’t be able to test it till the spring at best though.
I’ve tried to get this to work on my Hemi multiple times to no avail. I can get the screens to show but it says “change not saved” or something along those lines when I try to set it in the instrument cluster.
