I got under the truck today and measured the cab, and all of the error is in the cab mount. Shifted 3/8 inch to the driver side, I’m just going to loosen all the mounts and shift it over.
I hear this in my truck frequently as well. It sounds as if I'm going over cracks/bumps in the road, but im not, its smooth.Have some sound to my clicking from back seat.
Audio isnt the best and it sounds different in person but you get the idea..
Yeah, 4 per side, there is a good YouTube video where a guy did the job on his 1500 with a bottle jack and a 2x4 cut to length.Did you only move the cab? 4 bolts/mounts on each side right?
I’ve seen what these “mechanics” do these days. No one takes pride in their work, they cut corners, steal, break stuff and try to hide it, lose bolts and replace them with whatever they can find, or don’t replace them at all. I don’t need my truck tainted even more than what the factory already screwed up.Ratchet straps, bottle jacks and 2x4s even... good gawd! Are ya reading this @RamCares?
So when I picked up my truck from Ram I got a chance to talk to tech and he showed me the I guess what is a star case? and a thread or forum the techs are a part of and he confirmed it is a know issue pinpointed to the pass side rear cab mounts.
This is what they wrote:
"The rattle is coming from rear cab mounts. due to design oversight the center spacer tube rattles up and down against the top mounting plate portion of the mount and until a redesign of the mount is available this noise will not be able to be fixed."
"tried removing the lower black washer with the dimples and placing it on top with the dimples down to seperate the center spacer from the cab. Then we reinstalled the bolt with 2 washers between the center spacer and the large washer on the bolt. We were trying to clamp the center spacer between the silver top cap and the bolt. Still didn't change the concern. With the mount being fluid filled I can't remove the the center spacer to cut it down. Agreed that a redesigned mount is needed."
"wondering if this was the same issue for the star case that disappeared for a rattle at the A lar and they wanted you to replace front cab mounts.I am getting no where with star on concern they think the wrong mount was installed in location of rear of cab, knowing they are physically different mounts from the other mounts on cab."
"finally after 3rd revision of rear cab mounts the noise is no longer present"
Not sure what 3rd revision is but would love to find out. Hopefully my tech/dealer will find out and let me know if and when a redesign or fix is present.
I hear... crickets!Has anyone heard from @RamCares yet ? Has Ram got a fix for this yet as long as this problem has been going on, they should have something better than just swapping parts around.
