phatboy64
That sucks…. I have a 3500 diesel with Carli 3.25 off road lift, track bar, sway bar, rear add a pack, 37s on 20” wheels, 65r psi and it rides smooth. I can hit bridge expansion joint at 75 and it still is smooth. Is it possible that 35lbs is too low making the truck bounce?My hemi rides rough...rougher than any diesel I have ridden in. I'm Thuren 2" with softrides in the back on thick 37's running just 35lbs in the back. Thing will bounce you off the back seat after a bridge approach and then proceed to bounce 3 times as it settles down. I have new Fox 2.5 adjustibles in the back to soften it but they didn't help. Rear trackbar solved the rear from wandering, but no help on the bump and bounce.
Everything on the road is felt in your torso. I have a thread somewhere on here. I've given up (FYI).
