OEM Fender Flares or ?
StrayCat
Hi Chaps, after far too long making a decision on my wheels & tires, I finally bought a set of XD Hoss II wheels and new tires for my 2500 Big Horn. I got 18x9 " wheels with +18 offset and the stance is exactly what I wanted, a wee bit more aggressive than stock, but that looks great. I was gonna buy BFGoodrich T/A KO2's again. (loved them), but got these tires form Canadain Tire for half the $ and the reviews are as good or better than the BFG's so I took a chance on them. (fella down the road has them and loves them).
My issue now is, while I have OEM mud flaps to cover the new wheels/tires at the back, I could really use some fender flares.
OEM flares are $925 CAD + tax and Im guessing they don't come painted (I can paint them thats no big deal, I do my own paint work). Ive read online that folks have mixed views on aftermarket flares like bushwhacker, I want them small & discreet OEM style and no drilling required. Id also like to put the OEM mud flaps back on once the flares are on. What I really want is the plain/simple Laramy style flares with none of the faux bolts on the side.
What are your opinions on Flares, go OEM or other ?
The other reason I want a very subtle Flare is that I may use the OEM wheels in the summer months and I think the big flares will look awful with OEM wheel fitment
OEM are back ordered from stelantis just now too
Here’s some pics of bushwhacker oem style with +18 rims
flan, very nice , is the finish smooth or textured ? Id be painting mine and prefer a smooth finish.
do you have a product number from Bushwhacker ?
thanks
Many thanks !!
found a link on the Mopar store but it lists 2 different numbers for the flares for my truck ? no idea what the difference is:
here is the mopar store link:
https://store.mopar.ca/v-2022-ram-2...ior-ornamentation--moldings-and-ornamentation
they're all fit for a 2022 RAM 2500 BigHorn but it doesnt tell me the difference between the cheaper ones and the more expensive ones. Also hard to know if these come with hardware or not to mount them (likely not).
here are the various part numbers:
FRONT Flares:
Wheel Opening Flare Molding, Right - Mopar (6MS34GXHAC) - $73.80 CAD​
Wheel Opening Flare Molding, Left - Mopar (6MS35GXHAC) -$73.80 CAD​
Wheel Opening Flare Molding, Left - Mopar (6MS45TZZAC) - $105CAD​
Wheel Opening Flare Molding, Right - Mopar (6MS44TZZAC) - $105CAD​
REAR Flares:
Wheel Opening Flare Molding, Left - Mopar (6MS37GXHAB) - $85.20 CAD​
Wheel Opening Flare Molding, Right - Mopar (6MS36GXHAB) - $85.20 CAD​
Wheel Opening Flare Molding, Right - Mopar (6MS42TZZAB) - $120 CAD​
Wheel Opening Flare Molding, Left - Mopar (6MS43TZZAB) - $120 CAD​
This is an OEM off my 22. Laramie had a paint chip on it, so bought another one had it repainted and put it on. Lots of holes to drill.IMG_0901.jpegIMG_0898.jpegIMG_0899.jpeg
thanks Csaybert, I sure don't wanna dill holes. Maybe bushwhacker is my best bet. Some of the OEM say no drilling, but IDK, maybe that assumes the laramy fender is pre drilled (?)
thanks for this !
The 23 Laramie’s don’t even come with fender flares anymore. Used to be standard on the 22s and lower.
no need to drill holes for anything. clip the plastic off and use the mounting screws. I installed the new pw / rebel flares and they fit perfect.
Does anyone have the part numbers on the OEM flares that use to come on Laramie and up?
This is the Mopar OEM flares and spats I bought from moparpartsgiant.com for my 2019 Ram 2500. Just removed the clips as stated above and used 3M automotive doubled sided tape, worked just fine with no issues. Turned out the black spat on the front bottom of the bed in front of the rear tires wasn't needed, what was there was right. Also didn't need the screws just used the ones there holding the wheel well liners. I believe these will work on later models as well, but check for fitment, comes in black so had painted to match the truck.
Part Description
Subtotal
Part No.: 6510827AA
SCREW-HEX FLANGE HEAD TAPPING
[Ram | 2500 | 2019 | ETL | DG7 | Big Horn Crew Cab 4WD]
13.68​
Part No.: 6MS44TZZAB
MOLDING-WHEEL OPENING FLARE
Replaced by: 6MS44TZZAC
46.82​
Part No.: 6MS45TZZAB
Replaced by: 6MS45TZZAC
45.57​
Part No.: 6MS42TZZAB
WHEEL OPENING FLARE
51.70​
Part No.: 6MS43TZZAB
WHEEL OPENING FLARE
51.70​
Part No.: 68362312AC
SPAT-FRONT FENDER
5.08​
Part No.: 68362320AD
SPAT-REAR
7.68​
Part No.: 68362321AD
SPAT-REAR
7.68​
Part No.: 6510175AA
SCREW-TAPPING HEX HEAD
18.56​
Part Description
Subtotal
Part No.: 6510827AA
13.68​
46.82​
45.57​
WHEEL OPENING FLARE
51.70​
WHEEL OPENING FLARE
51.70​
SPAT-FRONT FENDER
5.08​
SPAT-REAR
7.68​
SPAT-REAR
7.68​
Part No.: 6510175AA
18.56​
Last time I ordered from there website they denied my purchase because my tradesman VIN didn't match having flares even though they will match up.
I just ordered the parts and didn't enter my vin number, (my) Bighorn(s) didn't include flares either, it was just Laramie on up.
So a few weeks ago I tried to order the rear wheel liners and they emailed me and said they couldn't order the parts without verification and requested my VIN. Thats when they canceled the order. I ended up going to my local dealer and bought them in stock.
