I just started to doing some prep work to install my Emergency Lighting for my rear window setup. I have to move some Oversize Construction and Farm Equipment between different properties around my area. I am working on the Back window setup first and later moving to the front of the truck (Slow Process). I just ordered
8 Low Profile Grille and Surface Mount LED's (Amber) and an
OPT7 48" Redline Triple LED Tailgate Light Bar for the top of the inside of my back window. They should arrive by the end of next week.
Here are a few Pics of the inside of the back window setup. I am planning on using .25 inch plywood to make the unit out of. Keep in mind, once the lighting arrives I will be cutting out most of this unit leaving an inch or two across the top above the head rests for the OPT7 unit and leaving the area between the rear headrest and the side of the truck for the Surface Mount LED's. All the middle of this unit you will see in the pictures below will be removed for visibility to the rear after I decide exactly where I want to mount the lights. Once finished, it will be covered with Speaker Box covering to make it look better. This is a rough idea and may change before I get to the finished product.
Like I said, I am still in the rough planning stages and will be posting more later in case you want to copy some of my ideas.
Also, here is a
link to some Reverse LED"s I installed a little while back for backing up in dark places. The one on top of the license plate is un-godly bright and pricey.
