sstoner911
The 6.4 and trans in the Scats is the same in the 2500s.Page 477 in my owners manual
"FUEL REQUIREMENTS — GASOLINE ENGINE While operating on gasoline with the required octane number, hearing a light knocking sound from the engine is not a cause for concern. However, if the engine is heard making a heavy knocking sound, see a dealer immediately. Use of gasoline with a lower than recommended octane number can cause engine failure and may void or not be covered by the New Vehicle Limited Warranty. Poor quality gasoline can cause problems such as hard starting, stalling, and hesitations. If you experience these symptoms, try another brand of gasoline before considering service for the vehicle. 6.4L ENGINE Do not use E-85 flex fuel or ethanol blends greater than 15% in this engine. This engine is designed to meet all emissions regulations and provide satisfactory fuel economy and performance when using high quality unleaded gasoline having a posted octane number of 87 as specified by the (R+M)/ 2 method."
The 6.4 in the high performance cars is a much different animal than the truck engines.
You won't get any pre-ignition and even if you did it would automatically pull timing much faster than you'd ever hear anything. The days of distributors and hearing a can of rocks in the engine due to improper timing (on stock engines) are long gone.
Run 87, save money, be happy. Don't overthink it.
Same tuning. You can run 87 but you are doing a disservice to the 6.4 and the money you invested in it.
