Crusty old shellback
so I just talked to my buddy who actually mixed the fuels at the bulk plant for the last 30 years and he said for the last several years, he said he believed since the 90's anyway that all fuel gets stabilizer at the truck rack (his terminolgy) and no additional stabilizer is needed he said it has been this way for a long time. He also said the only fuel that takes a little hit from sitting too long is if you have winter blend in a really hot climate as the butane will vent off but in reality not a big deal. He said there are actually 4 seasons for gasoline and winter blend is the lightest due to the amount of butane which is added to help cold starts. I asked how long would he leave gas before he would worry about it and he said "I dunno maybe a year" He also said of all the fuel Cennex has the highest standards. He also said all costco fuel west of Mandan is Cennex and cennex octane will always be higher than what is on the pumps.Noone should keep any gas sitting in the tank of any vehicle longer than 3 months unless treated with some form of fuel stabilizer which I do since my vehicles sit a while too. I always use Startron to preserve fuel and when I want to remove carbon buildup and clean up the fuel system I also use Seafoam.
Doesn't matter what octane you use because ethanol is your enemy.
The manual for the 2019s and first half of 2020 said to run mid-grade, so there was definitely some confusion before.I once thought the 6.4 in these trucks required higher octane. Until l was told to go re-read my manual..... It gets 87 now and runs just fine with no mileage impact (as if mileage matters here anyway lol)
I just took delivery of my 2023 Powerwagon this Monday and checked the manual since this topic seems to pop up from time to time. In the 2023 manual, it only mentions running 87. No mention of running 89 at all. Odd that its changed in such a short time. Maybe they re-mapped the tuning for 87 on the later trucks?The manual for the 2019s and first half of 2020 said to run mid-grade, so there was definitely some confusion before.
Thats good to hear. Part of the reason I went diesel was the cost of putting premium in my 2015 6.4 since I was always towing. Being able to go 87 helps a little. And if you’re towing on occasion that 6.4 is a perfect beast.
Us gas folk don’t hear this from the diesel crowd often! Not sure if perfect beast is the right nickname for the 6.4 but I will take the compliment!!!
I doubt there is a difference in tune in those years, but don't know that for sure.Are we 19-mid 20ers to ignore that and run 87? Is there a slight difference in tuning from factory that would be different?
Sent from my iPad using Tapatalk
Am I reading that correctly in the manual? Hemi's always needed minimim 91 octane.
Is this correct? Even for towing a 8k lb. RV?
I've been running 87 octane in my 2022 2500 6.4L 410 axle for about 10K miles. I recently switched to 89 it runs and sounds so much better I'm going to keep buying it. And I do try to buy top tier gasoline. I mostly use the truck to tow an 11k gvw 5th wheel
