ZF 8 Speed Oil/Filter Change
dieselscout80
I called about getting the transmission filter and fluid changed on my 2020 Ram 2500 6.4 with the ZF eight speed transmission.
It has +73,000 miles on it and only about 9,000 miles of trailers towing.
First dealership said $1,000.00 and the second dealership said $2.300.00. Both said it isn’t supposed to or need to be changed.
I think all the aftermarket pans ena the replacement of just the filter vs having to replace the plastic pan/filler each time is that true?
Question do any of the after pans give you a dipstick?
What does the OEM pan/filter coat?
The dealer will say that.. however ZF says to change the fluid.
Dorman 265850 Filter/Pan has a replaceable filter
No dipstick that I know of... just follow the ZF change procedure and it will be full
RockAuto has OEM for $264, Dorman for $159
Do you have a link to the ZF procedure/instructions?
Here you go... there are also several videos out there in YouTube land...
For the sake of not duplicating a post, I replied to the one you refer to that has the transmission service PDF.
In that reply, I have a few questions. Thanks!
The fluid is ungodly expensive too
Yeah, but still cheaper than a new transmission...
The trans will outlast the engine on the original trans fill. Regardless i don't have the 8speed so I'm not subject to the 1k fluid and filter change
ZF recommends changing the fluid at 80-120K (50-75K miles-ish)
I am somewhat inclined to believe they know what they are talking about vs RAM who doesn't care once the warranty takes a dump.
Where are you getting a 1K fluid/filter change?
Here in canada its 52$ per qt x13 and 350$ for the pan/filter assembly so its just over 1000$ for the materials to do the service
