Continuation post from https://hdrams.com/forum/index.php?threads/dans-2023-2500-tradesman-unlimited.14060/post-264276
Thanks to @AH64ID for the inspiration. Led me to explore further and dig into available pass-throughs.
From the thread linked above, I left off with this:
Under dash: From the light gray connector (D2621A) included in the upfitter kit Yellow/Violet(G425 pass through) tied in with Red/White at rear of truck on Aux 6 and a handy battery power Red/White in cab for later use with (dash cam, radar, whatever)
Under hood: the lower, light gray connector, ports 2 (Aux6) and 4 (G425 pass through) jumped.
Which left me with in-cab on the light gray connector (D2621A) Orange/Pink still looped providing ignition-on power to the rear of truck. And an unused Beige/Gray W550 Pass Through
As seen below:
Time to bring this connector into play. Also included in the upfitter kit. Black connector that goes under dash mating up with a white connector called D2433A
And time to break into this 4 wire bundle under the hood, commonly has a piece of yellow tape on it.
Untape this and you will see that 3 of the wires (W547 Beige/Dark Blue, W548 Beige/Brown, W549 Beige/Dark Green match the colors on the black connector for D2433A and the fourth wire W550 Beige/Gray matches the Gray under dash connector we used earlier on connector D2621A
As seen below:
