jak
Just curious, do you have the tailgate damper? I assume no different removing with or without? Thanks.
Great question! Makes me wonder if I messed up and did things in the correct order by accident, lol. I have the part (dampener) but have not installed it yet.Just curious, do you have the tailgate damper? I assume no different removing with or without? Thanks.
Part numbers and some detail pics of removing rear spats / trim. All of the push pins are accessible from behind, a little squeeze with some pliers and all popped out easy. The yellow ones are slightly hidden from casual observation as they are behind a brace structure but still reachable.TodaysThis weeks task lol.
These seals look like pure tedium and I'll need to remove/adapt some rear wheel well trim. Wish me luck
Thank you. I got it all sorted now but the castor tip is much appreciated.As you have found out, your tires are rubbing due to the offset and moving the tire/rim farther out than stock. And that can bee seen by how much your tire sticks out.
Stock factory bead lock rims with 35x12.50 17 tires on my PW do not rub any, even when at full flex.
You can try and run a little less castor on the front, say 3 to 3.5 degrees, and it may help and give you a little more clearance.
Confirmed no need to remove dampener to remove tailgate.Will we need to remove the damper if we remove the tailgate? I didn't pay attention when I installed mine.
