Post Pics of your 2019+ 2500 or 3500!
37x12.50 Recons installed on CJC Methods. Waiting on different center caps to go along better with the limited trim. And this is stock height for now
Ah perfect!!! Ya even better at +25!!!! I still wonder how mine would have been with 37s..............
I chose these tires due to their weight, like 72lbs which is less than Toyo MTs in 35s. I get the size with minimal weight. Add the additional sidewall for comfort, its a win for sure.
Yes, they are the stock 20's. It's stock height in the rear with just a 2.5" level up front. No spacers and did not do any trimming so it does rub a little at full lock in both directions. I've learned about where the rub point in the turning radius is so it's not much of a problem for me.
Which level did you go with?
Do you have factory rear air suspension?
That looks great, I'd like to run 37s on my 20" stock night edition wheels.
Removed front air dam, installing CJC Intercooler guard but the brackets powdercoat flaked off so waiting on new ones. Also removed the front sway bar, but improvement but I think I’ll get Carlis bar. Loving how this all turned out and without the air dam, really debating even lifting it at all.
Hi! My new 2022 Hemi Tradesmen build at 8,800 miles.
CJC fog kit with Baja SAEs
Thuren 2” springs
Thuren track bar
Thuren sway bar
Fox 2.0s
Access cover
Borla s type catback
Raceline Avengers 17x9 +20
37x12.5r17 KO2s
Going with the same suspension installed at the end of the month and this made me satisfied with the purchase! Looks great can’t wait to drive it.
