thestuarts
But under certain moderate acceleration like 6th gear 50mph and about half throttle acceleration to 65mph it seems to have a surge. I watched the boost gauge and you can see it oscillate by about 3-4psi when it's doing it.
I just took my truck out for a quick test with Banks iDash data logging enabled. I started at 50 mph in 6th gear, then I applied half throttle and accelerated to 65 mph. I did this multiple times across a wide range of engine temperatures. The data consistently shows the turbo boost does not surge or dip, but there may be a sampling limitation hiding the surge. The turbo boost data is only being refreshed every second, so we might not notice a surge. I will reach out to Banks and ask if there is a way to get a higher resolution refresh on the turbo boost.
EDIT: The horizontal axis represents 1/10ths of a second.
Nonetheless, I did have an epiphany. It is possible that @Dialed-In and @IronByron are experiencing a little weirdness immediately after the update because the dealership most likely issued the quick-relearn command which tells the truck to forget all learned behaviors and relearn the optimal engine and transmission parameters. I suspect the behaviors will improve over the next 1,000 miles. My truck has about 1,000 miles on it since it was last updated, and everything is working really well.
