That's really low compared to all the other posts here. I went to 65/70Unloaded 45 front 35-40 rear is plenty
Regardless of the other posts if you use actual inflation charts for the unloaded weight 45F and 35-40R is safe. I run 45/45 unloaded as my “unloaded” has tools and other gear in the box of the truck tire wear is perfectly flat across the tread as it should beThat's really low compared to all the other posts here. I went to 65/70
What if I weigh 200lbs. Is that still unloaded?Regardless of the other posts if you use actual inflation charts for the unloaded weight 45F and 35-40R is safe. I run 45/45 unloaded as my “unloaded” has tools and other gear in the box of the truck tire wear is perfectly flat across the tread as it should be
Im 245What if I weigh 200lbs. Is that still unloaded?
Jk. Lol
I ran 45 and 45 in my Nitto ridge grapplers all last fall during hunting season. Floated down the gravel roads like a Cadillac. Went back to 55 psi to experiment with mileage with no discerns em improvement. Will be dropping back down to 45 / 45 for a short trip coming up.Regardless of the other posts if you use actual inflation charts for the unloaded weight 45F and 35-40R is safe. I run 45/45 unloaded as my “unloaded” has tools and other gear in the box of the truck tire wear is perfectly flat across the tread as it should be
There is no Cat scale around me (300miles away) only the scale at my local dump so i have been going by that so it must not be very accurate as i was getting 2175KG with the front axle on my way out usually so it must be wrong and perhaps i should bump up to 50PSI front when unloaded! Thanks for catching that.Stock size?
The lightest I’ve seen my front axle weigh was 5140 with a bit of tongue weight. The new empty weight was 5260. I know the Aisin, sway bar, and emission stuff add up… but 45 still seems low to me at 4,940 for 18’s and 4,820 for 20’s
Im not worried about the ride the only reason i change my pressures is tread life lol.Yeah that seems light, unless you had a bunch of tongue weight applied.
5 psi likely won’t hurt the ride, but should run cooler if your at higher speeds.
Oh i get that i just mean i am used to the roughness from all the machines and equipment i have run over the years so the ride quality is not my goal lolI go for both, since the best ride and best tread life generally happen at the same pressure. That and you’re less susceptible to road hazards vs placard pressure all the time, and have better traction.
So what pressure do you's or would you's use when pulling your 5th wheels ?
New to the HD , just got a 2022 ,6.4 Bighorn from Rebel 1500. On the 1500 if you run more than 20% lower tire pressure than the door jam recommends it sets off the TPMS light. For you guys running 50 psi or less is your TPMS light coming on ? Thx.
25002500 or 3500?
3500's have TPIS and won't ever set off a warning.
2500's have a warning like the 1500, but I don't know the threshold. You can edit it with AlfaOBD too.
They will be if you don't lower the pressure limit on the computer…If the same as 1500, 20% window, my door jam is 65 frt, 70 rear, TPMS light would come on at anything less than 52 psi. I would like to run 50ish frt/back. So are your TPMS lights on under 52 psi ? Thx.
