If that is the case, why does my EVIC say zero but the iDash PID is at 96%? I am confused and certainly not understanding all this for sure.The one on the EVIC is the one that takes time into the reading, not the one on an iDash or Edge CTS.
Jay
Jay
Makes sense. Regardless of the % soot, when the 23-24 hour time comes up it will regenAlso I have seen it said in other threads that a regen will be triggered long before your true soot load gets to 100%. Not sure if that is correct but it makes sense.
The one on the dash is more of an indication of how much soot you are adding (driving style) or soot load over time. I would ignore the one on the EVIC and use the one your idash.If that is the case, why does my EVIC say zero but the iDash PID is at 96%? I am confused and certainly not understanding all this for sure.
At this piont a manual regen may help. If you don't see diff press change I would suspect an issue with the diff pressure sensor.
Jay
No longer regening on the 24 hour mark remains a mystery.
I don't think my % soot level PID is the same as what you are monitoring. Mine has nothing to do with time, it is formulated from the DPF pressure sensors. And without fail, when it reaches 100% a regen takes place. It also regens every 23-24 hours engine time.
I am pretty sure you are monitoring the same PID I am with the CTS3. Time is absolutely a factor.
When you are 12 hours since a regen it will be at 50%, 18 hours 75%, etc. while driving you can watch it gain 1% every
There is a whole thread going on the dash one. There is some good reading there but I wouldn't worry about that until you figure out your regen issue.
Jay
I like this and it is something I have not paid attention to. If you are correct, then my current 96% would mean the truck thinks it has been 23 hours since the last regen and will do another in two hours. Now I will just have to wait and see.
Yes, thanks. I messed up my train of thought on that previous post when I said the truck thinks it is at 23 hours so it will be 2 hours until the next regen! Makes me want to just go out on an unecessary one hour drive just to get it over with and know.You have less than 1 hour of run time until a regen. 96% of 14 hours is 23 hours and 2 minutes since last completion.
While you are correct, 100% is the soot loading value (based on differential pressure) where the engineers decided that an active regen should take place. The DPF will hold a lot more soot than what triggers a regen but it will cost power due to increased pressure across the DPF.There isn’t a PID for just DPF soot loading, the PID is for %age towards an active regen. That’s where the dash is nice, because it just shows you soot loading. 0% is a good thing, but you don’t know that the DPF is at 0% just with the PID.
I disagree. Once when I was only doing short trip local driving my CTS3 went to 100% and regened at about 15 hour point since the last regen. I believe the PID % soot is a reading of DPF pressures and is not age-related. When it doesn't regen until the 24 hour period, yes, it reads like you say, "When you are 12 hours since a regen it will be at 50%, 18 hours 75%, etc. ". Thoughts?There isn’t a PID for just DPF soot loading, the PID is for %age towards an active regen. That’s where the dash is nice, because it just shows you soot loading. 0% is a good thing, but you don’t know that the DPF is at 0% just with the PID.
Correlates exactly. I said, When it doesn't regen until the 24 hour period, yes, it reads like you say, "When you are 12 hours since a regen it will be at 50%, 18 hours 75%, etc. ". You haven't regened mid 24 hoursThis is getting crazy hard to keep straight! How would you correlate that to posts #s 46 and 48?
I was just getting to the point where I thought my soot level probably really is close to or at zero, but a regen will happen anyway in less than an hour of engine time.
On an odd note both GM & Ford have a PID for soot loading in grams but just like the percentage RAM uses it's a calculated PID based on differential pressure and some other monitored values.
Jay
That's the same thing I said, maybe I wasn't clear where I put 100% but I meant your CTS or iDash shows 100%.100% soot loading is where you get a power derate, an active regen is triggered much sooner (~45-50%) and you start getting warnings at 70 or 80% (can’t recall which).
And if a regen happens mid 24 hours, that would reset the 24 hours, correct?You haven't regened mid 24 hours
Yes. I have seen that happen on my CTS3 on my trips to Oregon. I believe the passive regenning is what allows the truck to go to the 23-24 hour mark for an active regen. It's when the truck is driven locally or for short trips that it will regen sooner as it loads the DPF faster, and no passive regens occur because it doesn't reach the required temps,I will add a little more confusion... When DPF temps reach 600 to 700 the DPF will do passive regen (usually towing or going up a hill) which will bring down the percentage shown on your iDash.
