https://hdrams.com/forum/index.php?threads/post-pics-of-your-2019-2500-or-3500.412/page-30Anyone running larger tires on OEM night edition wheels? Only see one truck so far. Interested to learn some specs. I love the oem wheels but the tires are too small for my liking. View attachment 4614View attachment 4615Found this one on EBay.
I definitely want to start with a 6 inch “quality” lift and 37s. Would be great if I could keep the OEM black wheels though. How does articulation play a part in a situation like that? Spacers needed you think? I don’t mind rubbing vs cutting up the fenders.If you look at where that guy had to trim, I think a spacer might make that even worse. You may have rubbing issues on the radius arm depending on the tire width you have, but also note that you’re probably going to have real trouble when you start articulating a setup like that. If it were me, I would at least level it before stuffing 37s in there, and unless you’re running a cummins, expect a noticeable difference in performance, so gearing may be in your future regardless, if you want to do it right and take stress off of your drivetrain.
You’re set with a quality 6 inch lift. I wouldn’t worry at all about articulation based rubbing issues with that much lift. If you are completely set on those stock wheels, get the tires mounted and check your clearances, if you need a spacer to make it work you can always get them afterward. The more you push the tires out away from the frame with a spacer the less trouble you will have with rub on the arms and the more trouble you will have with rubbing on the body. You can make anything work with enough moneyI definitely want to start with a 6 inch “quality” lift and 37s. Would be great if I could keep the OEM black wheels though. How does articulation play a part in a situation like that? Spacers needed you think? I don’t mind rubbing vs cutting up the fenders.
Money? Crap. That’s right. Let me get these kids to grandmas so I can get to work. They are almost done with virtual schooling. Thanks SquatchYou’re set with a quality 6 inch lift. I wouldn’t worry at all about articulation based rubbing issues with that much lift. If you are completely set on those stock wheels, get the tires mounted and check your clearances, if you need a spacer to make it work you can always get them afterward. The more you push the tires out away from the frame with a spacer the less trouble you will have with rub on the arms and the more trouble you will have with rubbing on the body. You can make anything work with enough money![]()
I was saying put spacers on the stock wheels to get into the +18mm to +25mm range. stillzaddy was running +25mm, so should be identical. And from Thuren's page again, he claims there is no difference in tire clearance (with a quality lift) unless you are going over a 3" lift, so leveling (according to him) won't help clearance. Again, I don't know this for a fact, as I don't have them on my truck, but people around here seem to hold Thuren in high regard.If you look at where that guy had to trim, I think a spacer might make that even worse. You may have rubbing issues on the radius arm depending on the tire width you have, but also note that you’re probably going to have real trouble when you start articulating a setup like that. If it were me, I would at least level it before stuffing 37s in there, and unless you’re running a cummins, expect a noticeable difference in performance, so gearing may be in your future regardless, if you want to do it right and take stress off of your drivetrain.
Haha. With 6" you should be fine clearance wise. I think the AEVs run 40s with only 3" of lift - but they make the wheel well much larger and requires a bunch of cutting.Money? Crap. That’s right. Let me get these kids to grandmas so I can get to work. They are almost done with virtual schooling. Thanks Squatch
Ha! Work smarter not harder right..Man, talk about a Lazarus thread. 4.5 years, that might be a record.
Great job with posting to a relevant thread instead of creating a duplicate, I'm impressed. And your truck looks great too by the way, those are some beefy tires.
Thanks man I am happy with how it has come together.
Wow, that looks really good! how does it do off-road? I have the same wheels, but with 275/65r20 BFG KO2's, and it rides very stiff in the rocky stuff...Thought I’d share my journey to 37s on stock wheels. First pic is with Nitto Recon Grapplers 35 x 11.50. I was very happy with these tires but just felt they looked a bit small on the truck. I love the stock wheels and wanted to maintain if possible. I already had Thuren 2 in level in front, stock in rear, coils and shocks all around. I also had the Thuren high clearance sway bar and rear track bar.
After a bit of research and digging through the forums I felt I had a good plan. Threw on the Thuren Alien Radius Arms and went to go have 37 x 12.50s put on. Was going with the Recons again as I was pleased with their performance. However.. I was told that due to the width of the stock wheel it would be “unwise” to put on a 12.5 tire. In fact Discount Tire said they wouldn’t do it and were not allowed.
So…. Ended up going with a Ridge Grappler in 37 x 11.50 x 20. They don’t make the Recons in that size.
It’s day one but I am thrilled with the look, feel, and drive of the truck. Was worried about them looking skinny but I personally don’t think they do and I love the stock “militaristic” look of the truck. Time will tell but I know the Ridge Grapplers have a great reputation and I am sure will serve me well.
ZERO rubbing at full lock
ZERO trimming or cutting was required
In summary Thuren **** rocks and I am very happy with the outcome.
As I understand will at minimum need the high clearance sway bar and alien radius arms to make this work. However the lift may be needed also.. I run my tires at 40-42 PSI and the thing rides better than a half ton in my opinion.
Hope this helps someone looking to do the same.
I’m gonna wipe now and go make sure my kids haven’t destroyed the living room..
Cheers!
View attachment 80323View attachment 80318View attachment 80319View attachment 80320View attachment 80321View attachment 80322
Thanks man!Wow, that looks really good! how does it do off-road? I have the same wheels, but with 275/65r20 BFG KO2's, and it rides very stiff in the rocky stuff...
There's certainly something to that. I don't really feel a substantial difference between the stock suspension and the Bilsteins but I definitely noticed a difference adjusting tire pressure. I used Jscan to lower the TMPS threshold, so now I can run around 50 psi instead of 70-80. Obviously I need to air back up when loading the truck heavy, but for most loads I'm not pushing the limits of the truck/tires so there's no need for them to feel like solid rubber every day. I'm guessing that's a big part of why 1500s feel softer, since they don't run the tires at the higher pressure....... It is night and day compared to the stock suspension and 70 psi. It rides as good or better than any 1/2 ton I’ve ever been in. .....
What’s Jscan and how can I do this? The low tire pressure warning is annoying… Also need to have my speedometer adjusted with the bigger tires if any tips on this!?There's certainly something to that. I don't really feel a substantial difference between the stock suspension and the Bilsteins but I definitely noticed a difference adjusting tire pressure. I used Jscan to lower the TMPS threshold, so now I can run around 50 psi instead of 70-80. Obviously I need to air back up when loading the truck heavy, but for most loads I'm not pushing the limits of the truck/tires so there's no need for them to feel like solid rubber every day. I'm guessing that's a big part of why 1500s feel softer, since they don't run the tires at the higher pressure.
