They are saying the filter is inside the converter and can't be replaced separately.They are calling a DPF/DOC a catalytic converter? They should at least know the names of the parts lol. If they cant be cleaned with a regen its happens when they get too plugged up but should never be full at 16k miles then they would have to be baked and chemically cleaned. Or replaced
There is not Catalitic converter there is a DOC and DPF both part of the same pipe they can be cut off/ cleaned and welded back together its a common practice but the dealer wont deal with the hassle as FCA is footing the bill for a replacementThey are saying the filter is inside the converter and can't be replaced separately.
Not sure who "they" are but they are wrong. Suggest you discuss with the Service Manager and/or Ram Cares for clarification of the failure and the fix.They are saying the filter is inside the converter and can't be replaced separately.
Hey,Yes it's under warranty. It's been 2 weeks and counting though waiting for the part.
It sounds like you have a faulty DPF like I supposedly have. From what I've gathered if you keep using the truck it will eventually go into limp mode ( 5 mph max ) I can't tell you how long that takes. You are indeed in for some serious frustration. I am on week 4 and still waiting for the new DPF to come in. Totally unacceptable. Ram should be taking care of it's existing customers first before before building new trucks. You could try buying this https://www.obdlink.com/products/obdlink-mxp/ and the necessary app, and try to do a manual regen yourself. That's what the dealer is going to try. I was told it wouldn't work and I needed the new DPF. Good luck.Just got the same error message yesterday on my ‘22 3500 with approx 13,700 miles. Gauge shows 100% and my closest dealer is over 180 miles away. Safe to drive or should it be towed?? This emissions crap kills me!
Its under warranty let the dealer send a tow truckJust got the same error message yesterday on my ‘22 3500 with approx 13,700 miles. Gauge shows 100% and my closest dealer is over 180 miles away. Safe to drive or should it be towed?? This emissions crap kills me!
Good call! Got the tow process started.Its under warranty let the dealer send a tow truck
Thanks for the info. Sending it to the dealer via tow sometime today.It sounds like you have a faulty DPF like I supposedly have. From what I've gathered if you keep using the truck it will eventually go into limp mode ( 5 mph max ) I can't tell you how long that takes. You are indeed in for some serious frustration. I am on week 4 and still waiting for the new DPF to come in. Totally unacceptable. Ram should be taking care of it's existing customers first before before building new trucks. You could try buying this https://www.obdlink.com/products/obdlink-mxp/ and the necessary app, and try to do a manual regen yourself. That's what the dealer is going to try. I was told it wouldn't work and I needed the new DPF. Good luck.
