RVTRKN
Received assembly today, removed and replaced sensor with my cracked tail lamp assembly sensor. Worked out real nice, everything seems to work on the test drive. A couple of tips if anyone else deals with the same issue.
First, the pins with inserts need to be replaced. Trying to slip in the assembly into the horseshoe shape plastic mold for the inserts can break, see picture of broken insert.
Prepped for new assembly.
I tried to unplug the plug with the locks opened and couldn’t get it to budge. So I removed the two screws that hold the sensor to the aluminum casting, and found out that you need to remove the sensor to unplug it. In the picture you can see the aluminum tab blocking the removal of the plug.
Two screws mentioned earlier that holds the sensor to the cast aluminum.
