chas0218
So i had a local shop install thuren front leveling springs, shock extenders and adjustable track bar along with an alignment. I got the truck back and it had a rattle noise when hitting larger bumps shopsaid it was because of the taller springs. I didn't think too much of it as i figured the springs were taller and likely making more noise than stock. Well I started to get a little annoyed by the sound and started investigating. Come to find out the shop that installed the springs and did the alignment didn't center the front end. My axle was easily 2" to the passenger side causing the drivers side spring to rub on a bolt head.
The spring isn't in horrible shape but chewed up a bit and the bolt the same. Would it be in my best interest to get the spring replaced? I got the front end somewhat straightened out but I'm pissed that they didn't do their job. Any suggestions on how to handle this?
