Recon Smoked Cab Lights Installation:
Stock:
1st: Remove the single screw on the back side of the lights. Then using a plastic pry bar, gently lift from beneath the opening of the screw hole:
2nd: The little white plastic release slide is a bit finicky, use a small screw driver and removed it entirely (it will slide back on, be gentle) Getting the connector off was a bit tricky as well (its really on there) I used a flathead screwdriver and "turned" it to break the tension, then it came right off. You really have to put some force into the connector to get it to seat properly when you install these lights. I suggest plugging them in and turning them on to ensure they energize before installing.
Overall, it took about 15 minutes. If you order these lights from Recon, there is a disclaimer for two separate cab light kits. One for fresh installs (you do not currently have cab lights) and one for existing installs (you currently have cab lights) make sure to get the right one.
It was a subtle difference, but I feel the subtle things on these trucks make the difference. The lights are not as bright as the OEM's, but they are smoked so that was known going into this.
