Best Airbags?
Rob122
I'm interested in adding some bags to my 2019 CTD 2500 to work with a toy hauler with a pin weight @ 1900# or so. Is there a general consensus on a reliable, reasonably priced brand?
Thanks in advance.
I’m happy with my airlift 5000s and day star cradles. That said I’ve never tried any other brand.
with a lift, a rear cradle / spacer is needed to run the bags. otherwise, you just need the bag kit.
You do not need bags for 1900lbs pin weight but if your set on bags the airlift and daystar cradles are great
It's not on a 5th wheel pin, this is on the hitch. I should have worded that better. I was worried about that much weight that far back on the truck. I don't have experience pulling that much so wanted to make sure I wasn't squatted flat.
I have 1500 lbs on the hitch of my 22 2500 hemi. Barely squats it, not enough to make it noticably nose high, anyway. I have the Andersen WDH and it pulls great.
Yes, I have one for my current setup.
Then again i would not worry too much as i have towed 1700 lbs on my 19 without a wdh and it sat level so with a WDH you should be fine. But if you are set on bags the airlift and daystar cradles are the ticket
