2” cradles?airlift 5k and 2" cradles here as well.
Gotcha. Makes sensewith a lift, a rear cradle / spacer is needed to run the bags. otherwise, you just need the bag kit.
It's not on a 5th wheel pin, this is on the hitch. I should have worded that better. I was worried about that much weight that far back on the truck. I don't have experience pulling that much so wanted to make sure I wasn't squatted flat.You do not need bags for 1900lbs pin weight but if your set on bags the airlift and daystar cradles are great
Yes, I have one for my current setup.You are going to use a WDH i assume?
Then again i would not worry too much as i have towed 1700 lbs on my 19 without a wdh and it sat level so with a WDH you should be fine. But if you are set on bags the airlift and daystar cradles are the ticketYes, I have one for my current setup.
