waveslayer
How do you enable it?Yes, it stays on whatever you had it before turning the truck off, on auto or full. No matter how long the truck has been off for.
Via the tuner?How do you enable it?
Which tuner?Via the tuner?
EFI Live, EZ Lynk, MM3...Which tuner?
After the first oil change, I have to add another item, changing the oil filter. I was so glad to not have to change the fuel filter in that same hell hole on a Duramax anymore. Now I have to change the oil filter in the same spot much more frequently than I did the GM fuel filter.
Is it something Alpha could do eventually? Agree that buying one of those just for the exhaust brake isn't worth it.EFI Live, EZ Lynk, MM3...
It's not worth getting one if all you want to do is turn the EB on
No, never.Is it something Alpha could do eventually?
It might be one of the differences between the C&C and the regular trucks, but my exhaust break remains engaged between startups. The auto settings also behaves differently depending on whether I'm in tow mode or not.Via the tuner?
Any tuner can do it. If you are asking what platform for tuning.. EFI, EZLynk, MM3.Which tuner?
I was with you in the beginning and thought it was just darn weird, but now I dont think its bad at all.Dial shifter.
Seconded. I love it now.I was with you in the beginning and thought it was just darn weird, but now I dont think its bad at all.
I just wish I would remember to dial it back to P before using the damn power button to shut the truck off. I miss a key and a column shifter! Yikes - I feel like I should add “and stay off my lawn!”I was with you in the beginning and thought it was just darn weird, but now I dont think its bad at all.
There are a couple of YouTube videos on installing them. I did it one person, but at one point it would have been real nice to have a second set of hands. Nice thing about the 2500 is the ground clearance. You have lots of room underneath to get the job done. Easy Peasy...I’m glad you mentioned the china clone of the oem bed step. I don’t have my truck yet but I ordered and received one from eBay for ~$220. It seems well made and looks identical to oem, except that the hardware looks to be typical stainless instead of that galvanized appearing stainless that come with the oem part.
I was glad to see a post by someone who had installed one as mine will wait in a box while I wait for my truck.
I still accidentally reach for the AC control thinking it’s the dial shifter.I was with you in the beginning and thought it was just darn weird, but now I dont think its bad at all.
I am really worried they will take away the column shift in the Cummins one day. Then I'll have to find a way to glue one in.I still accidentally reach for the AC control thinking it’s the dial shifter.
When I get in other vehicles, I do the same thing and reach for the AC controls but they usually have a console shifter.
Miss the column shifter in the older RAMs.
