My rig; 2022 2500 Limited Mega Cab CTD
Ok, did my initial testing in the garage, truck off. No issues. Fired it up, went for a drive and dear God the ANC kicked it and told me how unhappy it was. Rolled down a window, and it disappeared.
Got home and vowed to find the amp, which I did. Its under the dash, just adjacent to the parking brake pedal assembly. I removed the white harness, and put the PAC APH-CH03 white harness in-line with it. This is supposed to remove the ANC mic pins.
Also noticed that I have to reroute the main power wire a bit, and I’ve already covered this section in split tubing.
Taking the lil man to tee-ball practice shortly, so I’m hoping this fixes it! I will report back with results.
Put the KYKR 12” screen protector on last night. Top quality item!
Started ordering my air horn / tire fill setup.
Klein 100% duty cycle, waterproof, 150psi compressor. 2.8 gallon tank.
Will fab some brackets, mount them up and then get on with the trumpets, air lines and wiring.
Going to use aux1 as momentary for honking and aux2 to supply power to the compressor.
Got some more parts. Now I need to find time to install!
I like the idea of the cat filter but don't want to risk warranty coverage.
First pit-stop on the first family road trip in the new rig. Loving it.
quick photo on the beach. Off to rinse w freshwater.
Holy cow!! Sub setup looks amazing!!! I’m trying to keep up. All I’ve done is the BakFlip MX4, a Course Motorsports wireless charger mount, AJ4 Radio knobs. Also, my Thuren 3” lift just showed up. Will be ordering wheels and tires shortly. And then on to some subs!! Tell me again where the sub box came from?
Subthump.com; Extra deep mega cab box
I will say i have to fab some brackets to stop it from sliding forward, but otherwise its great.
