Hung the v1 on a blendmount today, and wired it and my dashcam to ign power thanks to @Brutal_HO
Next up, BMP rear CAT filter kit install which arrived today.
EDIT: i have the factory aux buttons, so I plugged the grey pigtail that came with the kit into the harness under the dash by the parking brake. I then tapped one of the looped wires for IGN power. The other looped wire is +12V constant. Then I connected an eye terminal to a bolt under there for my ground. Then tan power and ground up the A pillar and across the top if the dash.
Started taking out the storage bin, factory sub and flaps. 4 1/2” nuts for the flaps, and 3 10mm nuts for the bin.
Im not sure what to do with the storage bin mounting studs. Looks like they have to be cut off, but I’d like to find a way to remove them and reinstall them later should I want to.
I could not get the aux connector bracket off the fuse box, so I took the aux connectors of their bracket. Got the power and remote turn ons run to the back of the cab.
I will cover the power wire under the hood w split loom as soon as it gets delivered.
