Has anyone gotten a Maxcare warranty through MD?
I bought one through Mopar, 72 months unlimited miles.
A lot of folks seem to get it through their dealer too. I was hoping someone has through MD. They should do it as it is a Mopar warranty. I have two quotes hopefully they'll honor the lowest quote. 8/125k
Sheesh you all are patient. I got one off a dealer lot (had to drive 500 miles) after about a two month search but at a good deal below MSRP. There was a lot of like 12 identical ones (colors different) that came into this dealer over about a month period at THREE different MSRP prices... I got the first one and it was like 1800 bucks less than the next batch. The dealer had it as a "special" as it was lower. It checked almost all of my boxes except bedliner and even as a Laramie I couldn't get power fold mirror with the convex adjustment but I can live with that. Are you all still able to get price guarantees? And are they still coming in with "deletes" due to shortages? This is identical to mine color and everything https://www.goautoranch.com/api/legacy/pse/windowsticker/ram?vin=3C6UR5FJ7NG229080
This is mine. https://www.goautoranch.com/api/legacy/pse/windowsticker/ram?vin=3C6UR5FJ0NG213609
Apparently, units on lots quit moving when the gas went way up about a month ago and so, there apparently is more dealer stock right now AND some are starting to move lower on price. AS an FYI...
Dealer told me the price guarantee is automatic on sold orders. Mine came in with a $3000 bump on the MSRP so I was concerned but no worries in the end.
Having trouble checking rail cars over the phone. TTGX983239 tracking.
The Union Pacific system says your car arrived at its next scheduled stop this morning (April 11th) at 5:01am. Scheduled to arrive at the rail unloading yard on April 12th 1:45pm.
Thanks for the update
No problem. Sounds like your ordering journey is almost over. Congratulations! (If you use the UP system to track, you’ll want to speak the entire car ID (letters and numbers) into the phone. I never had much luck typing them in with their system
MD explained to me that there is a cutoff date for 2022 order (I don’t know what the date is), and at that point there will be no more orders, but the plant will continue to crank out production until all 2022 orders are complete. There is a 3’ish or so month window between order cutoff and next model year production.
The way the 22 build is going there might be some people getting 23's.
His is a loaded dually Laramie, mine is a Tradesman SRW, same color, same dealership. I ordered a simple build so it wouldn’t be held up getting built. You’d think a simple truck like mine would be built before his since I ordered it two weeks earlier but that’s not the case. Dealer said they build more Tradesman than Laramie’s which is why mine isn’t built like they are built on different assembly lines. Not sure how the lines are run but I believe the trucks are all built on the same line.
I feel for you, it should not still be a D status truck
For those of you picking up trucks at Mark Dodge, I can confirm that the price I secured back in October was the price I paid despite the $3K increase that showed on my sticker.
As many have noted here before, make sure you check your fuses. Every one of mine was able to be pushed in further with a slight click. Also check your tire pressures. The rears on my truck were at 79 psi and the fronts were at 69. I aired them all down to 60 psi for the drive home.
Only issue with the truck so far is the shark fin antenna on the roof is loose. I can lift it up enough to see underneath, so I need to get that checked out soon.
