Benson
I got my window sticker already but it doesn't have this on it.I was kind of disappointed--the dealer tore mine taking it off . . .
22 Production didn't start until August 6th, many details aren't right here.22 orders started in early May last year...if you look at the crowd source spreadsheet, the earliest that those first orders were received is Oct. The earliest a 22 order was delivered was at the end of August...a few other orders were delivered in mid Sept from June/July orders...so 3-ish is probably right but what does that really mean....3.5 months between when you can order a 23 vs when they start production?...doesn't mean '23 trucks will be on the lot in August...the more accurate window is that trucks won't be hitting the lot until 4-6 months after the 22 cutoff
True dat. The guy was asking whether his 2022 order would be canceled as we got closer to the 2023MY22 orders started in early May last year...if you look at the crowd source spreadsheet, the earliest that those first orders were received is Oct. The earliest a 22 order was delivered was at the end of August...a few other orders were delivered in mid Sept from June/July orders...so 3-ish is probably right but what does that really mean....3.5 months between when you can order a 23 vs when they start production?...doesn't mean '23 trucks will be on the lot in August...the more accurate window is that trucks won't be hitting the lot until 4-6 months after the 22 cutoff
Replenish the parts supplyIs that to play catch up for the outstanding orders?
It will be in the actual paper copyI got my window sticker already but it doesn't have this on it.![]()
How do you know if you are at D or D1? Neither gets a build sheet or window sticker so I"m curious what the difference is.It means at some point you were D1 and you have went back to D. Not uncommon. Mine did it. Now, I am back at D1.
The only place I am able to get my actual build codes is the dealerHow do you know if you are at D or D1? Neither gets a build sheet or window sticker so I"m curious what the difference is.
Your dealer is giving your more info than mine, I ordered in December with zero movement and all he tells me is "it's on track". I saw on here another user ordered his truck two weeks after mine and his is already shipped and they are both 3500's with HO diesel, he didn't know what to say to that.The only place I am able to get my actual build codes is the dealer
Is it the exact same trim and options? Sometimes that makes a difference.Your dealer is giving your more info than mine, I ordered in December with zero movement and all he tells me is "it's on track". I saw on here another user ordered his truck two weeks after mine and his is already shipped and they are both 3500's with HO diesel, he didn't know what to say to that.
Sheesh you all are patient. I got one off a dealer lot (had to drive 500 miles) after about a two month search but at a good deal below MSRP. There was a lot of like 12 identical ones (colors different) that came into this dealer over about a month period at THREE different MSRP prices... I got the first one and it was like 1800 bucks less than the next batch. The dealer had it as a "special" as it was lower. It checked almost all of my boxes except bedliner and even as a Laramie I couldn't get power fold mirror with the convex adjustment but I can live with that. Are you all still able to get price guarantees? And are they still coming in with "deletes" due to shortages? This is identical to mine color and everything https://www.goautoranch.com/api/legacy/pse/windowsticker/ram?vin=3C6UR5FJ7NG229080
This is mine. https://www.goautoranch.com/api/legacy/pse/windowsticker/ram?vin=3C6UR5FJ0NG213609
Apparently, units on lots quit moving when the gas went way up about a month ago and so, there apparently is more dealer stock right now AND some are starting to move lower on price. AS an FYI...
His is a loaded dually Laramie, mine is a Tradesman SRW, same color, same dealership. I ordered a simple build so it wouldn’t be held up getting built. You’d think a simple truck like mine would be built before his since I ordered it two weeks earlier but that’s not the case. Dealer said they build more Tradesman than Laramie’s which is why mine isn’t built like they are built on different assembly lines. Not sure how the lines are run but I believe the trucks are all built on the same line.Is it the exact same trim and options? Sometimes that makes a difference.
Ask the dealer for an updated copy of your POC. It will have it on thereYour dealer is giving your more info than mine, I ordered in December with zero movement and all he tells me is "it's on track". I saw on here another user ordered his truck two weeks after mine and his is already shipped and they are both 3500's with HO diesel, he didn't know what to say to that.
Does anyone have any bad experiences with the
KMC XD Series XD811 Rockstar II off-road wheel?
I seen that this morning. You posted a pic with your Fuzion and boat?There’s a guy on Military RVing that’s getting rid of a Jayco Seismic for $80k. Not sure what you’re looking for, but that was one trailer that kept my wife from sealing the deal on our Fuzion.
Samei feel ya! same boat![]()
